Go Back   Automotive Forums Car Chat > Buick > Regal
Old 11-28-2010, 01:21 AM
slixz85 slixz85 is offline
Question Flickering & Pulsating Lights Interiror
Hi i have a 2dr regal 3.8 and the interior lights will flicker and pulsate badly after i close the door. when i open my car door the lights go off including the interior lights but when i close the door they come on. almost as if backwards
I have read post about alternators and voltage regulators but didnt know if buick built the voltage regulator inside the alternator. dont know much about cars but heard the regulators are sometimes seperate to change them if that is the problem.
any tips? thanks
Old 11-28-2010, 08:20 AM
maxwedge maxwedge is offline
A990 racer
Re: Flickering & Pulsating Lights Interiror
Welcome to AF, moving this to the Regal forum below.
Old 11-28-2010, 09:29 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Important to annotate what year Regal.
For GM/Delphi alternators the voltage regulator is an internal part of the alternator.
Timeslip 08/12/06
AF Community Guidelines
Old 11-28-2010, 10:06 AM
Blue Bowtie's Avatar
Registered Offender
There were a LOT of Regals built since 1973, all of which used an integral regulator. Your initial statement is spot-on. Since they weren't available with a 231 V-6 until 1975 that narrows the possibilities to only about eighty variants. That should be a piece of cake...
slixz85,
Knowing the year is crucial. It may be a BCM, theater module, jamb switch, PCM, latch switch, headlight switch, UEC, wire harness, remote module, and probably a hundred other things. It is not, however, an external voltage regulator.
Old 11-28-2010, 10:18 AM
Question Re: Flickering & Pulsating Lights Interiror
thanks for the time so far yeah it is a 1992. not a car tech by far so heres all my cars specs
http://www.carfolio.com/specificatio...car/?car=18557
if needed to know. thank you
Old 11-28-2010, 11:32 AM
yeah its a 1992 http://www.cargurus.com/Cars/Specs-c...992-Regal.html <--- specs on car its a 3.8 optional for the custom i have cuz 3.1 came std
flickering/pulsating lights- Achieva jbjbjb Achieva 1 10-15-2008 06:41 PM
01 T & C Headlights Flicker & Dim Down Cntrysthbst Caravan | Voyager 11 01-10-2008 09:11 PM
97 olds 88-ls head & dash lights flicker Marshallscottjohns Eighty Eight 1 12-04-2007 08:20 AM
Battery Light Flicker & illumination CatScratch Contour 20 11-14-2005 10:47 AM
Lights Flicker, Battery Light Flickers, etc. smitty425 '88 - '91 Civic | CRX | Wagon | Shuttlee 5 11-26-2003 07:09 AM
