Go Back   Automotive Forums Car Chat > Ford > Contour
Old 11-09-2005, 01:41 PM
CatScratch CatScratch is offline
Unhappy Battery Light Flicker & illumination
I have a 98 Ford Contour SVT. I had a new battery, alternator and serpentine belt put in march of this year. A few days ago wile driving I noticed that as my car got to 3000 RPM the battery light begins to flicker and stays illuminated till my RPM drops below 3000. Any Ideas????
If I really crank the car to 4000 RPM I hear the belt sqweal. I did notice a little dust within the belt. Could I have a traction problem with the belt?
Old 11-09-2005, 02:12 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
is there a lot of tension between the belt?
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 11-09-2005, 02:14 PM
I can bend the serpentine belt 90 degrees.
or twist it.
Old 11-09-2005, 03:17 PM
Re: Battery Light Flicker & illumination
serpentine belt as in the belt on the drivers side of the car that drives the waterpump?
the alternator is on the accessory belt on the passenger side of the car.
"The CEG Nazi"
www.contour.org
Old 11-09-2005, 03:49 PM
Yes you are correct the accessory belt. I'm sorry.
Old 11-09-2005, 05:33 PM
ok, sounds to me like the tensioner is broke...can you move the tensioner pulley with your hand?
"The CEG Nazi"
www.contour.org
Old 11-09-2005, 06:23 PM
No I can't, I have to use the breakerbar in order to move it.
Could the vibration of the high RPM be shaking the connection. Maybe I should check my voltage. It should be running at 14.5 volts, correct?
On another note. I got an error code P0175 engine lean (bank 2). A wile back. Ist that the front sensor or the back sensor?
Old 11-09-2005, 06:24 PM
Old 11-09-2005, 06:38 PM
bank 2 is the front of the car.
none of the pulleys seem wobbly?
"The CEG Nazi"
www.contour.org
Old 11-09-2005, 06:49 PM
No they are not wobbly.
I replaced the sensor in (Bank 2) front sensor. But, the check Engine light is still on.
Old 11-09-2005, 06:58 PM
I do appreciate your insite and time your spending with me. I am going to get a bite to eat and will check back later.
Thanks
Old 11-09-2005, 07:25 PM
oh yeah, one more thing. P0175 is bank to rich, not lean. Just about everytime the car throws a rich or lean code, the 02 sensor does not need to be replaced. In fact, its working perfectly, and telling you exactly what is occuring. Its running rich or lean. Your fuel delivery is not caused by the 02 but rather from the pcm, maf, tps, etc. These cars run dead rich in the upper rpm's. Every contour we dynoed at the national contour meet last year that didnt have an aftermarket tune, pegged the wideband at 10:1 after about 5,000 rpms. Anyways, thats besides the point.
My next conclusion about your flickering light is perhaps your alternator is bad or there is something on the coils like grease thats preventing it from creating a good charge.
"The CEG Nazi"
www.contour.org
Old 11-09-2005, 07:29 PM
Alright, I did a little searching over on contour.org since this question has probably been asked a billion times, and it was.
Heres a TSB I found.
"Should a customer express concern about flickering headlamps, wavering illumination of the instrument cluster, interior lighting and audio unit at low ambient temperatures when starting and at idle in the first few minutes after starting the engine, the probable cause is an extremely high resistance in the battery wiring harness from the central junction box (CJB) in the engine compartment to the B+ terminal on the generator. To rectify the concern, an additional generator/battery cable should be installed."
Take a look at this thread:
http://www.contour.org/ubbthreads/sh...=&fpart=2&vc=1
The link from neco is dead, but theres a diagram on how to possibly solve the problem.
"The CEG Nazi"
www.contour.org
