Old 11-27-2010, 10:38 AM
58653376 58653376 is offline
92 Voyager Trans
Driving normally. Trany shifted into limp . When stopped lost everything . Now won't move at all.
Old 11-27-2010, 12:37 PM
mikefaster mikefaster is offline
Re: 92 Voyager Trans
Tranny fluid low? Has it been leaking at all lately?
Sometimes if you are 4 quarts low you get a false-positive reading on the dipstick; coincidentally, you won't be moving if you're 4 quarts low... You can try adding at least one; overfilling is not going to hurt anything... It just may overflow a little from the vent...
Any whining sounds?
Old 12-07-2010, 05:28 AM
urclueless urclueless is offline
Banned
I'd think that if you were just driving and it quit moving, you'd be wise enough to notice a huge amount of trans fluid leaking out of the trans.
we need to do some troubleshooting: when it is cold, start van and see if there is any attempt for it to move. if no, chances are that either the valve body pressure control valve is stuck open (rare), the pump has failed (rare) the transmission planetary gear set has broken (very common).
96 voyager trans slips when cold Soccer dad Caravan | Voyager 11 03-16-2006 06:15 PM
1991 plymouth grand voyager trans problem randysgirl0505 Caravan | Voyager 1 02-26-2006 04:17 PM
92 voyager - trans shifting problem bristol49 Caravan | Voyager 4 06-28-2005 02:04 PM
1992 Ply. Voyager Trans. Problem adamalltogether Caravan | Voyager 2 10-06-2004 10:21 AM
99 voyager trans problem BackSpacer Caravan | Voyager 5 07-14-2004 08:24 PM
