Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 11-26-2010, 08:46 AM
eaglehawk eaglehawk is offline
torque converter problem?
when i am in overdrive and usually accelerating at various speeds it starts cutting in and out like its a fuel delivery problem and if i put it in drive 3 it usually stops. my mechanic thinks its the torque converter. how can i be sure?
Old 11-27-2010, 11:45 AM
Blue Bowtie's Avatar
Registered Offender
Re: torque converter problem?
Connect a bi-directional scanner to monitor the TCC lockup circuit while driving. The operation of the TCC should closely coincide with the TCC solenoid actuation. The solenoid pulses rapidly to slowly bring the converter clutch into lockup so as to prevent a harsh engagement, so it can be difficult to detect lockup by feel.
A tachometer can also be helpful in diagnosing the TCC operation.
The Following User Says Thank You to Blue Bowtie For This Useful Post:
eaglehawk (09-23-2011)
Old 09-23-2011, 02:29 PM
sorry im late with this but my tranny mech. drove it and told me he could tell by watching the tac while it made a new noise, whirring sound , thta 4th gear was gone. does that make sense to you? should i relent to a rebuild? it has 117k and has not been touched.
Old 09-24-2011, 09:42 AM
maxwedge maxwedge is offline
A990 racer
If you want it fixed what is the option?
Old 01-25-2012, 10:50 PM
Pontiac Montana sv Pontiac Montana sv is offline
have a torque converter problem on my 2006 SV6...mech is referring me to a tranny guy; it was doing the surge thing, and the tac would show and you could feel it as the descriptions above...they have to pull the tranny to fix the tc...will keep you posted - gotta get it done, and at 117 thousand kilometres, no warranty...
Old 01-26-2012, 10:09 AM
Tech II Tech II is offline
Just a heads up....are you sure you are not feeling a misfire?
A R/T with a scan tool, will either show misfire or slippage....
Squealing torque converter Skitzy Express | G Van 4 04-05-2010 02:09 PM
05 tahoe torque converter out. . ??? help bcmagg Tahoe 8 03-22-2010 12:32 PM
2001 Flywheel, Torque Converter Problems... wen9197 Caravan | Voyager 2 08-10-2004 08:00 PM
Sunfire Torque Converter Problem mberry7185 General Discussions 0 09-28-2003 10:08 PM
Torque Converter Problem A-1Performance '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 08-16-2003 09:30 PM
