Old 11-24-2010, 05:36 PM
ClayBell75 ClayBell75 is offline
1999 Alero - Getting gouged on a new ABS unit?!
Hey, I have a 1999 Oldsmobile Alero. A year ago we got the classic 3-parter of TRAC, Check Engine and BRAKE light. Long story short, our dealership told us that the brakes were functional, but we would not have active ABS braking, so we went ahead with the car.
Now a year later... our back brakes are crunching, we have terrible stopping power at 45+ mph, brakes only seem to activate in the front, etc. Local brake shop takes off the wheels and our back rotors are rusted except for where the brake pad laid. By their estimates, it means the back brakes haven't been engaged in around 9-12 months.
SO... their solution is a new ABS unit along with a brake proportioning valve. The brake proportioning valve makes sense to me - makes sense as the root cause. But I don't necessarily want the ABS on a car I barely use.
BUT the repair shop says we HAVE to replace the ABS unit along with the proportioning valve because dealers will only sell them bundled. Yet I look on the Internet and find standalone brake proportioning valves for this car from reputable dealers.
So what's the deal? Are these guys just trying to rip me off for more labor costs, or does the proportioning valve REALLY need to be installed alongside a new ABS unit?
Thanks for your help!
Old 11-26-2010, 09:21 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 1999 Alero - Getting gouged on a new ABS unit?!
Did the dealership provide you with any of the ABS/Traction control system diagnostic codes to justify replacing the ABS Motorpack/Modulator which also has the electronic brake and traction control module (EBTCM) therefore expensive. The codes should be C1XXX, etc. Scan tool GM Tech2.
And welcome to AF.
Timeslip 08/12/06
AF Community Guidelines
99 Alero Emergency Break Light and ABS Light remain on. Need to get inspection. tekhak321 Alero 3 03-24-2010 01:29 PM
2000 Alero 3.4 ABS light on, code c1265 skeeter123 Alero 8 01-26-2010 07:51 AM
ABS Hydraulic Unit tips for rebuilding bertpalm General Discussion 0 01-16-2010 07:00 PM
New 1999 Alero Two Door Coupe Qwirks + Amp Install? tekhak321 Alero 3 03-15-2006 09:26 AM
Tags
1999 , abs , alero , anti , lock
