Old 11-23-2010, 05:09 PM
sanders71 sanders71 is offline
8.1 leaky front main seal replacement
since i can't find a haynes or chilton repair manual with an 8.1 liter in it.... how difficult is it to change out the front crank seal in a 01 silverado? can i do it with basic tools in my garage? or should i have it done professionally? just looking for advice. thanks
Old 11-23-2010, 05:22 PM
j cAT j cAT is offline
Re: 8.1 leaky front main seal replacement
with your problem of this seal leaking, how many miles , and what is the engines condition ?
It is possible the crank bearings are worn causing the leak.
I don't have a manual for the 8.1 L ...
Old 11-23-2010, 05:27 PM
777stickman 777stickman is offline
Radiator and everything in front of it has to come out. Need a special tool to remove and install crank damper. Need a tool to remove and install new seal. Not an easy job. Best left to someone you trust.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 11-23-2010, 07:10 PM
engine has 160k miles on it.
Old 11-24-2010, 12:34 PM
mileage not too high what about the engine condition ?
does the exhaust blow out oil smoke ...how long does it take for the oil to get black after an oil change ?
what oil pressures do you get ?
Old 11-25-2010, 10:31 PM
no smoke at all from the engine at start up nor under loads. oil gets black around 500-700 miles after change... rough estimate since it's been awhile since i kept track of when it turns black.
oil pressure of 40-50 at highway speeds, but has dropped a bit with a noticeable increase in the amount of oil that is leaking out.
Old 11-26-2010, 09:58 AM
if the oil pressure at idle is less than 20psi, oil turns black at 500miles, and you have oil in the exhaust this is usually a well worn engine and the crankbearings worn will allow the crankshaft to move too much causing leakages at the seals..a new seal will reduce this , but may not stop it..
Front Main Seal + timing belt questions thsorens Maintenance 3 12-03-2005 11:09 AM
front main seal TunerAdept Camaro Discussions 5 02-26-2005 01:12 AM
Front Main Seal on 92 Cavalier littlehurley Cavalier 0 10-10-2004 01:09 PM
Rear Main Seal Replacement mack737 Grand Cherokee | Grand Cherokee SRT8 3 06-07-2004 09:03 PM
