Old 11-22-2010, 08:55 AM
cloner3 cloner3 is offline
Replaced lower intake gasket, now won't start
I replaced the lower intake gasket on my 96 Blazer. I reconnected everything the way it was, I have the rotor in the correct spot{I think}, and it will crank, but not try to fire. I also noticed that distibutor cap does not stay on tight, but nothing broken there. Also, the fuel inlet does not want to seat into position. I don't know what else to do. I can't afford to take it to a shop. Please someone help. Thank you.
Old 11-26-2010, 11:22 AM
82Stang 82Stang is offline
Re: Replaced lower intake gasket, now won't start
I'd start with what you know to be wrong/out of whack. Check to make sure the rotor is in the correct spot and not 180 degrees off. Timing has to be on. The distributor cap must fit snug, otherwise how will the rotor contact the points to make spark. I'm wondering why the fuel inlet isn't lining up, need fuel to crank. Just keep trying, but if you have to force something, then it isn't right.
Once you know it is together right, then you can go back to the basics of troubleshooting when not getting spark. Check/replace plugs, wires, cap, rotor, coil(s) etc.
Hope this helps.
"When I was a kid my parents moved a lot, but I always found them."
Rodney Dangerfield
Old 11-27-2010, 07:39 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
On setting dist go to this link.
http://files.automotiveforums.com/ga...hp?photo=51302
MT
Just replaced lower intake gaskets. LeSabre97mint Windstar 17 11-11-2008 09:03 PM
Replaced Head Gasket,,,now won't start 98ZuZu Rodeo | Passport | MU 6 04-12-2005 07:09 PM
replaced valve cover gaskets, now won't start nika-tika Ranger | Courier 2 10-31-2004 11:10 PM
DESPERATE! just replaced intake gasket now hard starting sadgaowner Grand AM 1 02-01-2004 09:47 PM
Replaced Intake Gaskets Now won't run Butch03 Grand Prix 1 11-16-2003 06:54 AM
