Old 11-19-2010, 12:45 PM
bustinsails bustinsails is offline
map sensor failure symptoms
1991 Blazer has bad fuel economy, Idles good, but when to acceleration it has a real bad hesitation. I have to feather the accelerator to pick up speed. Could this be the MAP Sensor
Thanks
Old 11-19-2010, 01:20 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: map sensor failure symptoms
Thanks
Could be or could be other sensors and or other stuff.
What is the map sensor reading at key on engine off and engine running.?
Always check for good vacumn to map sensor.
Any check engine ligts or codes?
MT
Old 11-21-2010, 02:19 AM
viggy58 viggy58 is offline
that a V6 or V8? which engine specifically?
i had an 88 suburban with a 350 that had the same symptoms. cyl #1 plug was so fouled that it wouldn't fire. replaced em all and the problem was fixed. Any piston clang or stumbling when you try to punch the accelerator?
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Old 11-21-2010, 07:03 PM
82Stang 82Stang is offline
Thanks
Not sure if it pertains to your Blazer or not, but my 93 had terrible fuel economy and once I pulled the plenim off, I saw why. The fuel hoses in there leak pretty generously. Pull the oil dipstick. Does it smell like gas? Is the oil level higher? I'd check these because it is a common problem with our Blazers.
"When I was a kid my parents moved a lot, but I always found them."
Rodney Dangerfield
Old 11-21-2010, 07:25 PM
danielsatur danielsatur is offline
The symptoms of a bad MAP sensor is the same as a Massive Air Flow (MAF) sensor.
A bad MAP sensor, would give a bad signal for the air/fuel mix!
deliverability issues, fuel economy, and slow to react to the throttle position sensor.
Old 11-21-2010, 08:14 PM
Blue Bowtie's Avatar
Registered Offender
You can test the MAP with a voltmeter and vacuum pump/gauge. Backprobe the electrical connector for the MAP and turn on the ignition. Connect the vacuum pump and monitor the voltage as the vacuum changes. It should be something close to this:
MAP Sensor, very very strange! SebOber Grand Cherokee | Grand Cherokee SRT8 3 03-28-2010 05:02 PM
Are these intake manifold gasket failure symptoms? JStin Intrigue 2 03-07-2007 11:46 AM
02 sensor/MAP sensor baseball_playa1575 Metro 5 08-26-2006 05:10 PM
MAP sensor failure (frequent) ikmrbju Caravan | Voyager 2 12-08-2005 08:04 AM
Anyone with a bad MAP sensor or fuel pressure regulator?symptoms? 94cutlatized Cutlass Series 4 08-15-2005 06:12 AM
Tags
1991 , blazer , map , sensor
