Old 12-07-2005, 01:05 PM
ikmrbju ikmrbju is offline
Unhappy MAP sensor failure (frequent)
My 1990 Plymouth Voyager minivan (2.5 l, 4 cyl, non turbo)
keeps eating MAP sensors every 6 months or so.
I have heard, that general buletin went out saying there is now a MAP sensor valve kit available which is suppose to reduce the MAP sensor failure rate. It supposedly consists of vacuum hose(s) and a T joint.
Does anyone know where this kit can be purchased, or can it be made ?
My local dealer is clueless....
Old 12-07-2005, 04:15 PM
1thunder 1thunder is offline
Re: MAP sensor failure (frequent)
all you need is a vacuum bleed to allow a very small
amount air movement in the map vacuum hose to attempt to suck any moisture out of the hose
Old 12-08-2005, 08:04 AM
Re: Re: MAP sensor failure (frequent)
Thanks for responding.
How would I create this bleed valve ?
Where would I get the parts ?
