Front Hub Assembly 99 GM
Is the OEM front hub assembly a life of the vehicle or require replacement at a specific interval/mileage?
Re: Front Hub Assembly 99 GM
It is a replace as it fails item. You could replace on a schedule if you wanted. We have lost hub berings at different times. We have replaced them under warranty and sold some with over 150k on them and have never been replaced.
Being way2old is why I need help from younger minds The sooner you fall behind the more time you'll have to catch up. ![]() HEY Y'ALL--READ THIS Here are some of our old vehicles for sale.
I've only seen a handful of people need these changed. Like way2old said, they only need to be replaced when they are failing/failed. If you hear noise from them and you're sure it's not the brakes, than replace the noisy one. Otherwise don't worry about them.
![]() 2000 Mercury Grand Marquis LS - 119k / 14.89s @ 92.11MPH [ pictures | videos ] > Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok > Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB > BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms > CVPI aluminum driveshaft |
Thanks guys - that's what I thought, but not familiar with assemblies, only the inner and outer bearing set ups.
