Go Back   Automotive Forums Car Chat > Buick > Regal
Old 11-18-2010, 08:17 PM
tremayne0126 tremayne0126 is offline
Is this the transmission problem?
i have a 1998 buick regal GS and recently when i left work i was driving to get dinner and as i pulled from the light it felt as if the car was in neutral all it did was rev not move and im sure it was in drive i even tried shifting it a few times then i turned the car of then back on and i drove a block or to then it did it again as i try to gas it it just revs. bad transmission?
please help me before saturday and i just get the transmissin fixed
Old 11-18-2010, 08:20 PM
old_master's Avatar
Advisor/Moderator
Re: Is this the transmission problem?
Bring the engine to operating temperature, then check the transmission fluid level, could just be low on fluid.
You have to know how it works,
to figure out why it doesn't.
Old 11-18-2010, 10:12 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Also check the vacuum hose running from below the IAC valve to the fuel pressure regulator and to the transmission modulator. You can easily see the modulator if you look down from the upper radiator hose. If it is loose or cracked/roted it can develop vacuum leaks and cause shifting problems.
How long since you last replaced the transmission fluid, the filter may be getting blocked and that can cause slipping too.
Best regads,
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 11-18-2010, 10:35 PM
Ruley73's Avatar
Ruley73 Ruley73 is offline
Best regads,
Oscar.
The OP's car probably has a 4T65E transmission, so it does not have a vacuum modulator on the transmission. Even if it did, all the modulator affects is the stiffness of the upshifts. It would not cause a sudden catastrophic failure.
I agree with the suggestion to check the fluid level and go from there.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
Old 11-18-2010, 10:43 PM
olopezm's Avatar
Didn't know about the 4T65E not having a vacuum modulator, however it DID cause that on my pontiac when the vacuum line cracked.
Best regards,
Oscar.
Old 11-18-2010, 11:55 PM
Thanks a million will check and let you guess know
Old 11-19-2010, 04:10 PM
fluids gud
Old 11-19-2010, 10:25 PM
Blue Bowtie's Avatar
Registered Offender
Test cold and hot solenoid resistances for the "A" and "B" shift solenoids and the PWM solenoid. Test line pressure at the top test port both hot and cold. Make sure the filter upper seal is intact and pickup tube is not cracked. Verify the accumulator is not leaking and oil tubes are intact. Verify the forward band servo is moving freely and has correct pin clearance.
All this can be done with the unit still in the vehicle.
Old 11-20-2010, 10:16 PM
my mechanic sudgested a transmission tune or where they change the filter, flush it and put new fluid. start there?
Old 11-20-2010, 10:21 PM
olopezm's Avatar
Best regads,
Oscar.
That would be a good place to start, as you can see it was suggested before, if the oil and filter are the problem, it will be cheaper than taking down the whole transmission only to see it is in a good condition. If it's not then it will still be fresh oil which I believe it can be used on a transmission overhaul.
Best regards,
Oscar.
Old 11-21-2010, 01:01 AM
Best regards,
Oscar.
my mechanic said the transmission fluid was very dark like oil not redish at all and we went on to say he dont think its the transmission going bad do to the fact the transmission only slips when the car has been drivin for atleast 10-15 minutes and once the car go off and come back on it drives normal for another 5 minutes..... tune up monday
Old 11-21-2010, 09:45 AM
Registered Offender
Again, while the pan is off and filter is removed, check the oil tubes and accumulators for leakage, and remove the forward servo cover to check the servo piston seals for leakage and for piston binding. While the piston is out you inspect the pin for wear. Any transmission shop and most good general mechanical repair shops should be able to do that easily. It only requires removing another 6-8 bolts from within the pan area, and getting the dirty oil out of the accumulators is a good idea.
Personally, I would avoid the temptation of having them perform a powered flush and only have the pan and filter removed to drain by gravity.
Old 11-24-2010, 08:33 PM
he did it the way you said and it runs perfect also got the catalyc converter change just cause the code came up fixing total was 374.38 LOL
thanks you guys a million once again
Is this a problem with the Transmission??? Jenni75 Caprice 8 02-06-2010 05:16 PM
Transmission Problem SeanCL Cobalt 3 09-15-2009 08:16 AM
is this the transmission? justinkehr Grand Cherokee | Grand Cherokee SRT8 2 08-25-2008 08:20 PM
Is This The Transmission Modulator? Homerjay123 LeSabre 5 12-28-2006 03:06 PM
Could this mean transmission problems? juno Grand Cherokee | Grand Cherokee SRT8 15 12-26-2003 05:23 PM
