Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 12-10-2003, 06:36 PM
juno juno is offline
Could this mean transmission problems?
Hi everyone, I am new to this forum
I have a question about my Jeep Grand Cherokee with an Automatic transition. For the past couple of weeks I have been experiencing some strange behavior from my vehicle. When I accelerate on the freeway the car hesitates for about 5-6 seconds before pulling the car. It feels almost like the car is out of gas (but my tank is full).
Any ideas?
Old 12-11-2003, 09:06 AM
pod pod is offline
first post engine size/#of cyl and year
30 mpg in a brick on wheels isnt half bad...
Old 12-11-2003, 01:35 PM
bj's99jgc bj's99jgc is offline
Welcome to the board! Is it the engine that pauses or does the the engine rev and the tranny slip? Possible that the fuel injectors are dirty and not allowing the fuel/air ratio to increase with acceleration. If you slowly accelerated does it still feel like it's stalling? What part of it syntom makes you think transmission?
Old 12-13-2003, 12:51 AM
Thank you for the response everyone.
To answer your question Rod the vehicle is 6 cylinder – 1995.
BJ, I have been contemplating about the injectors you suggested, do you think that the injection cleaner (the one you buy at AutoZone for $2.00) will do the trick. Also, during normal operation of the vehicle (on normal streets) everything works fine, it is when I try to get on the freeway I start getting this problems.
Old 12-13-2003, 11:43 PM
trieck1232 trieck1232 is offline
Re: Could this mean transmission problems?
my 1996 jgc 5.2 v8 had the problem, i had the tranny flushed. how long has it been since you have had the tranny flushed?
Old 12-14-2003, 08:27 AM
Forgive me for asking stupid questions, but what is a “tranny”. And can it be done with minimum effort and tools or would I have to take it to the shop? Also how much will that approximately cost me?
Old 12-15-2003, 07:38 PM
jeep4me jeep4me is offline
Send a message via AIM to jeep4me
Juno~
Hi, "tranny" refers to your transmission. A do it yourselfer could tackel this chore but it's easier to take it to a good shop and have it done. The filter is replaced and the old fluid is replaced with new. This service should generally run about $40 to $80 depending upon the shop. I would recommend having this done if it has been a while. Hope this answeres your question...
Jason
Old 12-16-2003, 12:32 AM
Thanks Jason or the answer. What about the fuel filter, do you think that needs changing too. I haven’t had any major tune-up on the car since I bought it. What ealse would you sujest me to include into the tune-up. I have a list, perhaps you could add to it.
1. tranny
2. spark plugs with spark plug weirs
3. tier pressure
4. ??????
Old 12-16-2003, 09:00 PM
Juno~
Hi, so you've decided to get the tune-up done??? Here is what I would have replaced/checked while having the service done:
1. transmission flushed/new fluid
2. new spark-plug's and wires
3. Radiator flush (or at least checked and toped off)
4. Fuel filter changed
5. Serpentine belt checked
6. Tires rotated
7. Battery and alternator checked
Hope this helps you out. Anyone else have any other ideas??? This should be a good start. Take care~
Jason
Old 12-20-2003, 05:52 PM
I went ahead and fallowed you advice and replaced the transmission flushed, installed new spark-plug's and wires, replaced the fuel filter. But the problem is still there.
Any other ideas?
Old 12-21-2003, 06:15 AM
injunarts injunarts is offline
Your jeep has a throttle body assembly. There is a rubber air tube which runs from the big black air cleaner box so you can locate it very easy. Loosen the screw and remove the tube from the throttle body.
It will reveal a metal round hole. Look down it and there is a metal door which you can move with your finger by pushing it.
If this hole and behind the door are very dirty (black) buy some carb cleaner and get an old tooth brush. Spray the cleaner down the round metal hole while holding the door open. Take the tooth brush and clean the entire area. Do it more than once if needed. Then take the cleaner again and spray off the excess.
Reinstall the rubber tube and tighten the screw.
There is a motor inside this medal assembly.
When it gets very dirty it will cause your veh to die or hesitake on accelation.
This motor is called a throttle position sensor and DOES NOT move like it should if too dirty.
Hope this helps.
Dave
Old 12-21-2003, 11:08 AM
Thanks Dave I will give it a try and let you know if that works.
By the way what kined of cleaning spray should i use?
Old 12-21-2003, 01:14 PM
When you go to parts store to buy just tell them you need a carb cleaner and they will get you what you need.
Dave
Old 12-23-2003, 08:32 PM
RUSH1 RUSH1 is offline
Talking Re: Could this mean transmission problems?
hello juno i had the same problem with my grand cherokee your problem is the o2 sensors there is one on the front of the catalytic converter and one on the back. these are the shape and size of a spark plug.
i drove my self crazy with the fuel inect cleaners , throttle body etc.
try the o2 sensors i just replaced the one in front.
Old 12-26-2003, 04:35 PM
I did what you told me Dave and it looks like it’s working!!!!!!!!!! Thanks man.
I didn’t do a lot of testing but so far its running smooth. I will test more tomorrow just to make sure.
If the problem comes back I will check the O2 Rush1.
Thanks everyone
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
