Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Bolt on Parts
Old 11-17-2010, 04:38 PM
Cavalier9696's Avatar
Cavalier9696 Cavalier9696 is offline
Send a message via Yahoo to Cavalier9696
Bov
K i HATE my BOV sound..lol Let me try and descibe what it sounds like. It's like Chi chi chi chi chi. Not the Pa Chi lol. There a way of adjusting the bov to change the sound? Or is it the bov spring? I was thinking it's cause IM only running 5psi and not pushing enough boost for the Pa chi. Or does adjusting the vac line do it?
1995 Eclipse RS 5psi
Garret T3/T4 Turbo, Procharger FMU, TurboXS BOV, OBX Evolution 35mm External WG, HKS Intercooler, Apexi DP, Apexi exhaust.
Old 11-18-2010, 09:58 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Bov
You can not 'adjust' the vac line to the BOV.
Looking at the Turbonetics BOV, it looks like it is adjustable. It almost sounds like either A) it's opening to quickly, or B) the chi chi chi is compressor surge, where the BOV basically isn't opening soon enough. The air needs to be released, and if it has no place to go, it goes back into the turbo, and will destroy it.
I would turn the screw to adjust it and see what happens. Try small adjustments each time.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 11-18-2010, 12:30 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Bov
Yea I hope thats not compressor surge. Try to loosen up the spring some if you can. However some bovs do sound like that on low boost levels so you might also want to rev it while under the hood and make sure it is in fact releasing air.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-18-2010, 02:41 PM
Re: Bov
Ya I have giving it some gas at a sit still and the BOV wont go off. So I adjust the spring just but unscrewing the back end of the bov?
Old 11-18-2010, 03:00 PM
Re: Bov
I just adjusted the spring and it still makes that same sound. Guessing it's just cause low psi. But the guy who had it before me could make it go off just by reving it. I think he was on 5psi also.
Well, I called turboxs and the guy said to take some of the washers out where the spring is. He said 4 to 5 should be enough. Which there was 10 in there to begin with. Guess the guy I bought it from put that many. Turbosx guy said that was way to much. But even with 5 washers, it still makes the same sound. He said that it's just that type of BOV. It's going to make that sound. Guess IM going to get a new one. I hear a type s is good.
Old 11-19-2010, 09:04 AM
david-b's Avatar
Dave is THAT guy
Re: Bov
If you post of a vid of the sound, it would help out a lot. You said you took out washers, but did you actually adjust the screw? And when you rev it at idle, can you feel air coming out of it when the rpms are dropping? If there's no air coming out, its surely not opening and NEEDS to be adjusted more.
75 Monte Carlo
Old 11-19-2010, 12:07 PM
Re: Bov
The guy told me that the tension for the spring should stay as tight as I can get it. There is no screw, what I have to do is just loosen the backend of the BOV. And when I rev it does nothing. It piston just sits there. Only time it goes off is when IM driving down the road. MY bov is 2nd from the the bottom the type h34 http://turboxs.com/shop_prod.php?what_category=2 the whole top cap of it is what I adjust, but like I said the guy at turboxs said to leave it tight which really doesn't sound right to me. I'll try to record the sound this weekend.
Old 11-20-2010, 02:51 PM
Re: Bov
K here is a vid. You might need to turn your sound up some to hear it.
http://www.youtube.com/watch?v=uUcP7HWxOss
Oh ya does it matter how I have the IC piping going? I have the right to the turbo and the left to the intake. Is the air just going the wrong way? And is there a certain distance the bov has to be away from the intake. Mine is by my battery.
Old 11-21-2010, 12:54 AM
ned032002's Avatar
ned032002 ned032002 is offline
Re: Bov
Sounds like compressor surge to me.
Old 11-21-2010, 11:40 AM
Re: Bov
I have done everything. Taken washers out, put washers in. Just wondering if my piping is wrong or what?
Old 11-21-2010, 05:03 PM
ned032002's Avatar
Re: Bov
Take a picture of the engine bay and post it.
Do you have another bov to try?
Old 11-21-2010, 05:21 PM
Re: Bov
Naw thats the only one I have. Going to take some pics and post them real fast.
Old 11-22-2010, 08:30 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: Bov
Problem 1: TurboXS
Problem 2: Too tight
The BOV should not release at idle (shame, guys) unless you're running a super small turbo. Positive manifold pressure needs to be built.
That said, problem 1 should be addressed ASAP.
Kris
2012 Genesis Coupe 2.0t
Old 11-22-2010, 10:06 AM
Re: Bov
Originally Posted by LandoAWD View Post
Problem 1: TurboXS
The spring is to tight? Shouldn't it go off with just pushing on the gas with car in neutral. I have seen alot that can.
Old 11-22-2010, 10:08 AM
Re: Bov
TurboXS uses a silly washer/spring combo. Please note the first problem I cited...
Kris
Atmosphere BOV V.S Recirculating BOV drakered6 Bolt on Parts 4 06-07-2010 02:00 PM
1g bov diagram?(How BOV works inside) Nayr747 Engine, Transmission and Drivetrain 24 12-22-2005 11:22 AM
FS: Stock turbo with 2g bov BOV sganc4life_4 Off-Topic 5 11-28-2005 03:46 PM
Bov between BOV and Throttle Body HiT-TheNos420 Off-Topic 6 09-28-2005 03:50 PM
1g bov vs greddy type s bov sganc4life_4 Off-Topic 8 02-19-2005 11:58 PM
