View Poll Results: 1g BOV vs Greddy Type S BOV
1G BOV 3 37.50%
Greddy Type S BOV 5 62.50%
Voters: 8. You may not vote on this poll
Old 02-17-2005, 08:55 AM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
1g bov vs greddy type s bov
Ok, Im trying to decide on which bov to get. I know with the 1g bov, I can crush it(someone explain this please) but greddy type s is very popular for some reason. Difference in price is about 70$ depending on the person. On ebay I found a 1g bov for about 50 i think, the greddy is about 120, I just want to know if the greddy type s is that much better.
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 02-17-2005, 09:21 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: 1g bov vs greddy type s bov
Crushing the 1g BOV allows it to hold more pressure than it would uncrushed (unless you are running a ton of boost, there is no need to crush it). I would recommend the 1g over the Type-S. Save your $70 and get a boost gauge!
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 02-17-2005, 06:58 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
The 1G will hold more boost than your stock T25 can boost safely (15psi). It is cheap, and works. HOWEVER, you will have loads more fun with the GReddy; its an event every time i drive my car, and the blow off nosies are really cool, turn a lot of heads, etc etc. Holds boost just as good as the 1g perhaps... so save a little, and get the GReddy, youll love it.
The daily driver. The weekend cruiser. The lazy shop hog.
Old 02-18-2005, 03:16 AM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
ya go with the GReddy. you may not be thinking it now but you are going to want to upgrade your intercooler pipes too...
Old 02-18-2005, 08:25 AM
I actually planned on getting new intercooler pipes after the bov. Thanks a lot for your opinions and I think ill go with the type s
95 Eclipse GS-T
Currently:
Soon lol
Old 02-18-2005, 04:34 PM
Killa_DSM's Avatar
Killa_DSM Killa_DSM is offline
You can't go wrong with the Type-s!!! A great Bov.
"Life begins at 20psi"
97 Eclipse GST-X 5spd
PTE 5031e/pte 880cc/vr4 fuel pump/Devils Own Water injection 12gph nozzle/pre turbo meth injection/fmic 28x10.5x3.5/greddy type-s bov/12" K&N/FP intake/dsmlink/gm 3.3 bar/maft/blitz ebc/act 2600/act 6 puck/SS Clutch line/3" turboback.
Old 02-19-2005, 12:13 AM
Black99GSX Black99GSX is offline
I have the Type-S myself and love it. Wouldn't change it for anything.
Mods: K&N FIPK, Upper IC Pipe, GReddy Type S BOV, FP Big16G, FMIC, Denso 660's, DSMLink V2, GReddy Profec B, GReddy Turbo Timer, Buschur Racing 2.5" Downpipe, 2.5" High Flow Cat, 3" Thermal R&D Catback, FPR, Walbro 255 fuel pump, Autometer Phantom Air Fuel/Boost/EGT Gauges, ACT2600, Buschur Racing Front and Rear Strut Bar, Symborski Shifter Kit
Old 02-19-2005, 09:30 AM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
i would recommend saving a little longer and get the upper ic pipe at the same time as the bov that way you dont need to adapt your stock plastic flange for the type s to fit and you can just get a uicp thats flanged for the type s. if you want to save a little money ive seen some type s bov's on DSMTrader.com for less then 120. you can probably even get a uicp and type s for about 150-170
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 02-19-2005, 11:58 PM
i found on ebay already a type s and intercooler pipes flanged for it for about 240 with shipping, so i think ill do that
95 Eclipse GS-T
Currently:
Soon lol
