Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 11-17-2010, 09:43 AM
08TR196 08TR196 is offline
Help needed ASAP
didnt get much of a response on the high rear end so..
My idea is to get underneath and try to bleed the pressure until it levels out. Problem is I dont know exactly which line that would bleed the pressure.
I wanted to know if anyone had any knowledge of the system..? and can instruct me on which line to bleed.
Old 04-27-2011, 09:37 PM
Schaff68 Schaff68 is offline
Re: Help needed ASAP
i dont know what all there is to your system, but sometimes on semi's , leveling valves go wacky and may cause front axle to be higher or lower then rear or the truck may lean, so, check and see if it has a leveling valve for the air suspension
Old 08-14-2011, 08:47 AM
erichzeppelin's Avatar
erichzeppelin erichzeppelin is offline
Did you ever get your high rear end figured out? I have the same problem. I'm getting a DTC C 1770 which is a stuck vent solenoid. Still trying to figure out how to drop her.
Old 08-18-2011, 10:17 PM
Never mind, I fixed it.
Heater Help Needed ASAP!!!! tonskiguy Silverado 5 12-20-2004 11:54 AM
Help needed ASAP!!! 1PhatCX '88 - '91 Civic | CRX | Wagon | Shuttlee 2 08-23-2004 11:29 AM
serious relationship help needed ASAP hotgrlzracin Stress Release 14 04-27-2004 03:14 AM
MK2 1.6 Carb to 1.8 Digifant GTI engine Conversion. Help Needed ASAP! im_reg Golf 0 01-13-2004 07:06 AM
Help help need asap fom a mod bengi681 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 08-31-2003 12:32 AM
