Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 11-17-2010, 09:06 AM
0073735963 0073735963 is offline
Door key turns but doesn't engage/disengage lock
Morning,
I have a 2004 base Chevy Impala that I had to have the door jimmy'd open after I left my keys in the car (first time for everything). Anyways, a while after that happened, I noticed my key can turn in the driver's side door lock but it doesn't engage/disengage the lock. The key will only turn the standard amount, it doesn't freely spin around. It took me a while to notice because I always use the fob. The fob works fine to lock/unlock the door as does the inside manual lock. When the door is opened/closed or when I go over bumps, I can hear something rattling or hitting something on the inside of the door.
I've watched some videos on how to take apart the door and wanted to take a look but was wondering if that sounds like something I could fix. In the videos, I see the long bars for the inside door handle and the inside lock that run down across the door..I'm not sure if it would be that since it's the outside lock cylinder that doesn't work but I'm not sure what I would be looking for at that point as the videos I've seen do not cover the outside lock.
Thank you to everyone for your time.
Old 11-17-2010, 12:42 PM
inafogg inafogg is offline
Re: Door key turns but doesn't engage/disengage lock
sounds like the linkage on door lock was knocked off when slim jim was used
they are plastic clips so its either broken or just got knocked off
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Turn key and nothing. no dash lights or response from the key turn at all. grrrtyson Cherokee 3 04-26-2010 12:12 PM
1997 Turns but doesn't start kenc195 Rodeo | Passport | MU 57 09-22-2006 09:06 PM
Engine turns but doesn't start rogersdodgers Escort 9 07-12-2006 09:56 PM
97 dodge gr caravan key turns but nothing happens "HELP" warren172 Caravan | Voyager 0 06-29-2004 06:56 PM
Ford F150 Pickup Squeels when key turned but won't start kottoman F Series 3 04-28-2004 07:17 PM
