Old 11-14-2010, 09:23 AM
pint4 pint4 is offline
Engine cooling light is on-99 Grand Prix GTP
The engine cooling light is one and I have enough coolant. I am told there is a low coolant sensor that goes bad. I have received conflicting information as to where it is located. Some say on the plastic coolant refill bottle and others say on the radiator. Can someone help me and does anyone have instructions perferably with a picture or two that would help me to my own replacement?
It is a 1999 Pontiac Grand Prix GTP.
Thanks,
Bob
Old 11-14-2010, 09:27 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Engine cooling light is on-99 Grand Prix GTP
On the radiator. About 4" below the radiator filler neck. We have many old threads on it. Just remove the passenger side headlamp for easier access.
Timeslip 08/12/06
AF Community Guidelines
Old 11-15-2010, 07:01 AM
Is there a easy way to search for the other threads that relate to this topic? When I try I seem to get all kinds of other subjects thrown into the mix. Is it easy to fix even for someone not highly experienced?
Thanks
Old 11-15-2010, 09:03 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Did you recently change to prestone brand dex-cool? My car did this right after I got a coolant flush and used prestone instead of ac delco brand dex cool.
Cleaning the sensor would work for short periods of time but eventually I just got sick of it and changed it out.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 11-17-2010, 10:41 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
It's located just below the upper transmission cooler tube on the passenger side radiator tank. It's about 1-1/2" square, and has a wire harness connector coming off toward the ground. Here's a link to the picture from Delco's website:
http://webcaps.ecomm.gm.com/internet...umber=10096163
The round part facing up in the picture is what goes in the radiator, and the wire you see is the spring loaded retainer that actually holds it in place. Hope this helps.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 12-06-2010, 07:37 AM
Brent S Brent S is offline
FYI: My Low Coolant sensor issues ('99 GTP) were caused by brown sludge deposits, from the plaguing Lower Intake Manifold gasket. I got the gasket changed, and now my radiator filler neck remains spotless, and never had another Low Coolant light issue.
-Brent
'99 GTP
99 grand prix gtp. Annoying problem no heat!..Cold!! tiffany716 Engineering/ Technical 1 12-09-2007 10:55 AM
Multiple Problems on 99 Grand Prix GT, Wiper/Horn/Lights/Door daveoneeighty Grand Prix 6 09-14-2006 11:13 PM
99 Grand Prix GTP 4 Door Drive Window cpqindy Grand Prix 0 08-12-2004 10:11 PM
99 Grand Prix GTP? Clark_24_2k1 Grand Prix 20 07-12-2004 10:49 PM
How to program remote for 99 Grand Prix GTP billnye12 Grand Prix 1 01-10-2004 10:54 PM
