Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 11-11-2010, 04:02 PM
chuck's chuck's is offline
auto t/c switch 1999 suburban
The indicator light on the switch for 2 wheel drive does not illuminate after engine start up.Once the tranfer case is shifted to different positions and then back to 2 wheel,the indicator light comes on.The tranfer case does shift properly.Would it just be an issue with the switch itself or could there be a larger issue??Thanks. chuck's
Old 11-12-2010, 07:28 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: auto t/c switch 1999 suburban
What transfer case?
Auto or regular?
If Auto 4W a good transfer case capable scanner willtest it out for you.
Does transfer case shift right or just light not right?
MT
Old 11-18-2010, 11:14 PM
Used a snap-on scanner the other night and the scanner shows that the tranfer case is shifting.It also indicated that the light circuits were ok.I will now check how much the switches are worth.It is an auto tranfer case.Even with the scanner connected,the indicator lights were not illuminating properly.Chuck's
Old 11-19-2010, 06:10 AM
MT-2500's Avatar
AF - Advisor
Sounds like the bulbs are shot or circuit board.
Let us know how it goes.
Good Luck
MT
Old 11-19-2010, 01:14 PM
intimadatorsquizz intimadatorsquizz is offline
It's the switch my 99 Tahoe did the same thing.
Old 11-21-2010, 08:22 PM
aztecf aztecf is offline
The solder joints inside the switch crack, its just a matter of taking the switch apart and resoldering the connections.
Jeff
Old 01-29-2011, 01:00 PM
Finally got to look at the switch.Found that the three pins of the three pin connector had the solder joints broken.Took some solder, an iron and resoldered the pins.The indicator lamps now work.
chuck's
1999 Sebring Conv. right side mirror doesnt move Foxypsycho Sebring | Sebring Coupe | Convertible 0 04-24-2010 05:00 PM
1999 Suburban Door Lock Problems jay.smith C/K 13 02-19-2008 11:26 AM
Suburban Were can i get a transfer case for my 1999 Suburban RingOfireNetAdmin Suburban 1 06-01-2005 11:14 PM
1999 Suburban Confused front fan control switch. sdcarlson Suburban 2 04-20-2005 11:37 PM
1999 Suburban --NEED HELP removing Steering wheel casing/ignition switch Cindy Koby C/K 3 02-21-2004 12:26 AM
