Go Back   Automotive Forums .com Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-10-2010, 02:34 PM   #1
groovyforster
95.5 Isuzu Rodeo running rich
I have a 1995.5 Rodeo with 3.2L and 160k miles. It runs rich. Black smoke from exhaust. No codes. Air to fuel ratio is 2:1. Timing is good. What should I do to fix this?
groovyforster is offline   Reply With Quote
Old 11-10-2010, 07:57 PM   #2
Cat Fuzz
Re: 95.5 Isuzu Rodeo running rich
Where are you getting your air/fuel ratio? Ideally, air/fuel ratio is 14.7:1.
You could have any of a number of things wrong. Leaky injectors, bad fuel pressure regulator, coolant temp sensor, plugged up air filter.....that's off the top of my head.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Cat Fuzz is offline   Reply With Quote
Old 11-11-2010, 10:02 AM   #3
groovyforster
I have a snap-on mt-2500 brick. One of the pids displayed is the air to fuel ratio. I have already replaced all the injectors, fuel pressure regulator and air filter. I did not replace the coolant temp sensor because I was getting readings on both the dash gauge and the snap-on scan tool. Any other ideas would be greatly appreciated. Thanks.
Old 11-12-2010, 12:30 PM   #4
95.5 Rodeo
95.5 Rodeo's Avatar
When I had this problem, it turned out to be the oxygen sensor.
http://www.automotiveforums.com/vbul...d.php?t=258045
Good Luck,
Dale
95.5 Rodeo is offline   Reply With Quote
help! 95 tahoe stalls and runs rich no cel riverbadboy Tahoe 1 08-14-2009 09:16 AM
1985.5 Porsche 944 runs rich quadracer_87 924/944/968 2 06-23-2009 03:47 PM
95 Silverado 350 TBI running rich?? fritcr C/K 2 03-29-2009 11:25 AM
isuzu engine runs rich Gary Fernando Rodeo | Passport | MU 7 10-12-2007 10:46 PM
1994 Isuzu Rodeo running rich Jim Donoho Rodeo | Passport | MU 26 03-08-2004 08:46 PM
