Old 11-09-2010, 04:02 PM
gpgt98 gpgt98 is offline
NO HVAC speed 5
Have changed the blower motor and had no speed 5. Then I changed the resistor. Still no speed 5. Is there a fuse that controls this? 98 GPGT single manual contol. 115K.
Old 11-09-2010, 04:43 PM
doctorhrdware doctorhrdware is offline
Re: NO HVAC speed 5
I think there is a fuse and maybe a fusable link. May be some that has the wiring diagram can point us in the right direction?
Old 11-09-2010, 05:35 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: NO HVAC speed 5
Look in the intrument panel fuse box (glovebox) for the fuse marked HVAC-HI.
Timeslip 08/12/06
AF Community Guidelines
Old 11-10-2010, 02:45 PM
Angry Re: NO HVAC speed 5
Just replaced the 30 amp fuse. No luck.
Old 11-10-2010, 04:21 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: NO HVAC speed 5
Check for voltage at the fuse socket with the ignition on and the blower turned to speed 5.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 11-10-2010, 05:12 PM
BNaylor's Avatar
Re: NO HVAC speed 5
The other possibility is a bad climate control head unit. Position 5 from the switch supplies a ground to energize the hi-speed blower relay which happens to be located on the blower motor resistor assembly but that was replaced.
Timeslip 08/12/06
Hvac GregGP Grand Prix 1 10-21-2010 12:01 AM
Speed Sensor spgoethals Taurus | Taurus Wagon 3 04-06-2009 06:35 AM
Can I put a 5-speed in an 84 Fiero? Protoclown Fiero 1 03-23-2009 12:08 AM
Speed sensor maybe transmisson???? c_evans1979 Caravan | Voyager 8 03-15-2009 12:27 PM
