Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-09-2010, 01:00 PM
letsgoracing letsgoracing is offline
Leaking brake line
I have a 1994 ford mustang with a 3.8 liter engine. i have notices a leaking brake line but for some reason it does not leak all the time. the spot for this leak is located underneath the radiator it has 2 brake lines that goes beneath it. when i see a puddle about the size of the bottom of a pop can i have reached up to feel the line and it is dry as can be but is brake fluid on the ground. i put new rear brakes,calipers, and rotors and has a mushy pedal i bled it and still seems to leak randomly. the line is always dry up to master cylinder. also on a note the master cylinder has remained full even after having bled the system any help would be awesome cause i want to start driving it again
Old 11-11-2010, 09:12 AM
Davescort97 Davescort97 is offline
Escort guy
Re: Leaking brake line
Welcome to AF!
What is the color of the fluid? If it is a brake line it should be clear. If it is one of the lines running from the transmission (automatic) it should be red.
Replacing Leaking Brake Line & Bleeding System! 1995VaFordCrownVic Crown Victoria 1 11-27-2007 09:33 PM
Camry 90 Noisy Weak Front Brakes,Leaking Brake Line Thaqalain Camry/Camry Hybrid/Vista 9 08-29-2005 06:24 PM
Oil Pan Leak repair and brake lines muddler Crown Victoria 3 07-08-2005 04:13 PM
92 maxima brake line leak jamey666 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 09-23-2004 07:38 PM
