Old 11-08-2010, 08:02 PM
bamaboy2008 bamaboy2008 is offline
help
2002 Pont Grand Prix GTP 3800 motor,,would not crank pulled 02 sensor and now cranks but RPMS race away
Old 11-09-2010, 02:39 AM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: help
Hello and welcome to the forum!
I'm not sure what you mean, the engine didn't rotate when you turned the key to the ON position or it rotates but won't start?
If your problem is the last one and according to the RPM's problem try cleaning your MAF sensor with a non-residue CRC contact cleaner. Also give a good clean to the IAC valve with carburetor or throttle body cleaner.
Best regards,
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 11-09-2010, 03:24 AM
doctorhrdware doctorhrdware is offline
Re: help
Or try disconnecting the maf sensor and see if the rpms even out, if it does the maf sensor is bad or dirty. As suggested above try cleaning the sensor, and crc also has maf sensor cleaner. Which has been designed exclusively for the maf sensor.
Old 11-09-2010, 10:08 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: help
So your car starts if you take the O2 sensor out of the manifold? Which one did you remove? The O2 before or after the cat converter. If it was the one before the cat, your cat converter may be plugged, and depending on your milage may be covered under warrenty still.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Help! triciamuldoon Grand AM 6 11-11-2010 09:49 AM
help i need help i need help i need help i need help lamborghiniman Diablo 1 11-24-2003 01:33 AM
Help Help Help Help Help lewdaka03 Jetta/Vento/Bora 1 06-02-2003 01:57 PM
Help Help Help Help Help Help Help Help Help Help del_blond '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 04-05-2002 03:05 PM
Help Help Help !!!B20b!!! Help Help Help HondaCivic405 Engineering/ Technical 0 04-05-2002 01:51 PM
