Old 11-08-2010, 03:47 PM
triciamuldoon triciamuldoon is offline
Help!
I am currently experiencing a slight shake in the steering wheel when my car reaches about 110 km/hr. I am a little concerned, any ideas what might be wrong?
Old 11-08-2010, 06:22 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Help!
Welcome to AF!!
The first place to start is with the tires. Have them re-balanced to see if they are balanced properly. If the problem still exists then have the CV joints checked along with the tie rod ends both internal and external. Any of these items can cause the issue you indicated.
Old 11-08-2010, 06:24 PM
Re: Help!
well i had the tires balanced and rotated about 6 weeks ago, and there is still a bit of a shake. I am just concerned because i have to make a long trip with very short notice and I am just wondering if it will cause problems on the highway.
Old 11-08-2010, 06:31 PM
thephantom1492 thephantom1492 is offline
Re: Help!
jack the car, try to move the wheel, you'll probably find some play (there should be none) on one or both side.
You might have a safety hazard here. ball joins, tie rods... or something else...
Old 11-10-2010, 11:01 PM
lugnut02 lugnut02 is offline
Re: Help!
I have a 2002 2.2L Grand AM it suddenlt started to run very rough and lost power like it wasn't hitting on all cylenders , I checked the plugs and 2 of them was wet with gas does any one know if this could be an ignition problem and where should I go from here .
Old 11-11-2010, 01:33 AM
Re: Help!
You should have started your own thread, but you probably have a faulty coil pack. the pack hold 2 coils, which each one fire on 2 cylinders
Old 11-11-2010, 09:49 AM
Re: Help!
I apologize for not starting a new thread , I am new to these forums but finding out they can be helpful Thank you for your responce.
