Old 11-08-2010, 03:40 PM
crazyduetoiowa crazyduetoiowa is offline
Send a message via AIM to crazyduetoiowa Send a message via Yahoo to crazyduetoiowa
Ignition switch/Passlock
Hello I have an 03 s-10. I replaced the ingnition switch in it and now when I connect the battery up it turns the odemeter on as well as the security and battery light are always on. The truck will crank but it dies right away. What did I do wrong?!?
Please help!
Thanks Derek
Old 11-20-2010, 01:59 PM
ctwright ctwright is offline
Re: Ignition switch/passlcok
I unhooked the battery before working on my brothers s-10, it was an 01, I was changing the motor mounts, after I got done, hooked the battery back up, he then turned it on, and it was acting crazy, he got it to crank, security light was on and rpms kept jumping up and down up and down. It had me worried for a minute. He then remembered he had a security code that he was supposed to put into the radio, he did that then it everything was back to normal, not sure if this is the same issue you are having or not.
Old 11-21-2010, 02:36 AM
viggy58 viggy58 is offline
http://www.automotiveforums.com/vbul...light=passlock
Try a neg battery cabel disconnect for 30 minutes.
Then go threw the relearn.
You will need a a slow battery charger hooked up when doing it or a junper car on it.
Key on for 10 minutes untill security lught goes out.
The key off.
Do that 3 times in a row.
On the next start if it relearned it should start.
If not find a good repair shop or dealer with a body capable scanner to check it out.
Ther is two different system.
Does your horn or headlights do any flashing or honking?
For more info on anti theft systems get a good factory repair manual All Data DIY online sub.
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Not Starting, did ignition switch - no help Royalwapiti Intrigue 10 02-10-2010 01:37 PM
Ignition Switch mb8668 Eighty Eight 9 11-01-2009 08:41 AM
Anyone know anything about ignition switches? angel_iz378 Cobalt 3 09-08-2009 11:52 AM
1999 Denali, R&R Ignition Switch, Passlock problem ownerfixer Yukon 2 06-18-2007 11:07 PM
Connection between Passlock & ignition switch thnhan Malibu 4 10-25-2006 06:03 PM
