Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 11-07-2010, 08:58 PM
Missy79's Avatar
Missy79 Missy79 is offline
1994 Thunderbird Heater Core
Hi,
If someone can help me understand on how to replace or fix a heater core, I believe that is the problem with my car. Air conditioning works, Heat only blows out cold, I do remember that on the passenger side floor something leaked there coolant? does heater core have liquid? Yea I know I'm stupid , but any help I greatly appreciate
Thanks
Missy
Old 11-07-2010, 09:42 PM
inafogg inafogg is offline
Re: 1994 Thunderbird Heater Core
yes your right!!the heater core has antifreeze running through it
if the h/core is leaking antifreeze on floor you need to replace it
good luck
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 11-07-2010, 10:12 PM
Missy79's Avatar
good luck
Thanks? A little more help if possible. how much does that usually cost?
Old 11-08-2010, 08:42 AM
Scrapper Scrapper is offline
AF Premium User
if you cant get it out from behind clove box your going to tear the dash apart.
Old 11-08-2010, 12:28 PM
http://www.autozone.com/autozone/rep...00c1528006ba2f
looks pretty involved for a DIY
i dont no the labor time 8-10 hrs maybe x $60-$80 per hr
you can always by-pass to fix leak but then you have no heat
Good Luck
Live For Today
Yesterday is gone,
Old 11-10-2010, 07:00 PM
97Bird's Avatar
97Bird 97Bird is offline
Welcome to the forum Missy79. Look at post #7 in the first page of the Tech help thread (first thread at the top of the Thunderbird forum). It describes how to replace a heater core. Usually when the heater core starts to leak you will get a film on the inside of the windshield when you turn on the defroster. Have your cooling system level checked and pressure tested before attemping to replace the heater core- to be sure that is the problem. The AC drain hose might have come off which would cause water (not antifreeze) to leak into passenger side floor. If you have automatic temp control, look at my post at the top of the second page of the Tech help thread to see how to run the self test of the system. You may have a blend door actuator that isn't closing the blend door. The blend door position determines if the airflow goes through the heater core (for hot air) or bypasses the heater core (for cold AC air). Good luck.
The Original 97Bird
1994 Deville Heater Core R & R jija Deville 5 12-13-2012 11:23 AM
smell antifreeze - NOT heater core samdavon Dakota 1 12-11-2009 12:19 PM
1987 Thunderbird Heater Core & Blower Motor marksatterfield Thunderbird 5 03-01-2009 10:52 AM
95 Thunderbird heater core stopped up matt6288 Thunderbird 1 01-19-2008 10:36 AM
1994 Surburban, Heater Core- Question wilsont1 C/K 1 01-12-2004 04:24 PM
