Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 11-06-2010, 01:35 PM
zoemayne zoemayne is offline
engine swap question
00 3.4L 120K miles
I got an 00 impala coolant flooded the engine (because of the intake failing I assume) and from what I hear that job is $1200+ and alot of people i know that the car will never run the same i should just change the engine.
So im changing the engine. I found 2 different 05 engines the salvage yards say their direct fit but from what i've read the vin must have an E or whatever and the 00 impala only is a direct fit to 00-02.
My question is how can i get the 05 3.4L engine to fit. Is it a different ECU etc? The salvage yard said they can swap it for me for $450 and the engine is $650 w the the 30 day warranty. Its a newer engine so i'de rather get it instead of and 00-02.
Old 11-06-2010, 02:19 PM
maxwedge maxwedge is offline
A990 racer
Re: engine swap question
Pretty sure the pcm programming is different, bu the interchange books used by salvage yard have all the required info as to whether and what is required for this.
Old 11-06-2010, 02:29 PM
the place where im buying the engine from is gonna do the job so that just makes this process a whole less complicated. if the engine is bad or it does not fit than they gotta fix it if it needs a ecu/bcm they probably have it. I just should find out if they have computers to diag the car.
dakota engine swap jpuckett13 Dakota 0 08-23-2010 07:21 PM
4.3l cross-platform Engine swap questions. Jeremyj Performance 2 04-26-2010 10:36 PM
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 09:40 PM
Engine Swap Question SolReaver '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 7 01-23-2002 02:37 PM
engine swap question tookosher Engine 7 07-10-2001 12:50 PM
