Old 11-06-2010, 08:36 AM
gkeys55 gkeys55 is offline
Brake Lights not Coming On
I'm having problems with my back brakes not coming on all of a sudden...we push the brake peddle but no lights, it's not the light bulbs I checked them...so I'm thinking wiring, but can some one tell me what color is the wire that directs the lights to come on. I might have a break in one of them and have to fix it. My Radio went dead to.
Thanks
Old 11-06-2010, 09:37 AM
inafogg inafogg is offline
Re: Brake Lights not Coming On
have you checked the fuses?light green wire for stop lamps
im using 95-03 manual what year??
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 11-06-2010, 10:20 AM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
If the cruise control stops working too, it could be the "Brake ON/OFF switch" who is defective or the fuse for this switch is blown. Check the switch under the brake pedal.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 11-06-2010, 03:39 PM
It wasn't fuses I checked that but I will check under the pedal...Thanks!
Old 11-06-2010, 03:40 PM
It's a 2001 3.8
Old 11-06-2010, 08:18 PM
wiswind wiswind is offline
Here is a picture of the Brake On Off (BOO) switch on my '96 windstar.
In my case, a wire broke off.....not uncommon.
However, I had a issue with the brake lights intermittently not working at a later time and replaced the switch.
It is a easy DIY job.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 11-07-2010, 10:34 AM
Easy fix but it's still not working.
Old 11-07-2010, 11:29 AM
Selectron Selectron is offline
I know you did say you've checked the fuses, but did you check fuse #11 rated at 10 amps - it's in the interior fuse panel.
Old 11-07-2010, 12:02 PM
Check voltage after the switch when it's pressed to know if the problem is upstream the switch or downstream the switch. If it's downstream, it could be the brake light wires that go to the lamps. It could be a short circuit too.
For the radio, check voltage between the radio fuse and GND.
2004 Sentra 1.8S-No brake lights?!? brynfrt05 Sentra | 200SX (USDM FWD) 11 06-08-2010 09:30 AM
1999 Passat - Changing Brake light bumpsetspikeki11 '97+ 0 03-09-2010 07:38 PM
emergency brake light comes on freakyfire05 ZX2 8 02-11-2010 10:19 AM
Brake Light Switch uspres2020 Escort 5 09-28-2009 12:11 AM
Brake lights problem corollastudent Corolla/Matrix/Voltz 1 07-20-2009 12:39 PM
