Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 11-05-2010, 05:52 PM
skinnyhoover skinnyhoover is offline
Loose transmission linkage
Hey everyone. I have a '93 Crown Vic and it seems that the linkage between the shifter on the column and the transmission is gradually slipping. Wasn't that bad at first, but now reverse is somewhere between park and neutral and to get it into park you need to literally "slam" it to the left. Drive seems ok, but for all I know it could be going into 2nd or something. It's actually slipped out of park before and rolled across thparking lot (luckily not hitting anything)! Anyways, it's been getting progressively worse, and I was just wondering if anyone knew where to start on the diagnosis or what it would take to correct this problem.
Thanks!!!
Old 11-06-2010, 11:03 PM
Wheel7 Wheel7 is offline
Re: Loose transmission linkage
I don't know if this is your problem but there are 2 bolts which may be torx head under the steering column where the shifter cable attaches to an arm on the column. They have a reputation for coming loose and if one drops out, it is almost impossible to shift. To see it you have to remove the plastic cover under the steering column, I don't remember but you may have to remove a metal cover too.
The Following User Says Thank You to Wheel7 For This Useful Post:
94&92Astro (04-22-2011)
Old 11-18-2010, 11:18 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
I think it is a Torx 10 head; It is not 100% necessary to remove the metal cover, but it might help to get more light down there.
Once you're down there check the BOO switch too, it is located in front of the brake pedal and it might be sticking since the car shifted out of park (which shouldn't happen unless the brake pedal is depressed). See if the car shifts out of park without depressing the pedal, if it does taking out the boo switch and giving it a good clean might do the trick after all it is a spring-loaded contact.
Best regards,
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 12-09-2010, 08:32 PM
Hey, thanx guys I just now got to it, and it was the 2 torx bolts you mentioned. Lucky for me the plastic and metal cover were both missing (old cop car) so it took me all of 5 min. Shifter's nice and tight now, better than when I bought it. Thanks again!!!!
Old 01-20-2011, 04:39 PM
Mdvanpelt Mdvanpelt is offline
Same thing happened to my '93 Crown Vicki. Tightened the bolts and she drove like a dream for about two weeks. This week, got in, started the car, went to put it in gear and heard a loud "thunk" sound and the gear shift was loose--couldn't put the car into gear. Had to have it towed home. What should I look for or do now?? Thanks.
Old 01-20-2011, 06:13 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
There is a cast aluminum shift tube that is bad about breaking. Remove the lower portion of the dash, then be sure to take the gear indicator string loose. Remove the 4 bolts holding the steering column and lower it. Remove the plastic trim around the column. Look at the part that holds the shifter in place. it probably has a break in it. I think dealer is only place to get a new one.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 01-20-2011, 06:43 PM
Thanks. I'll look tomorrow. Dumb question--will a Ford dealer sell me the replacement tube?
Old 01-20-2011, 08:36 PM
olopezm's Avatar
That's right, you can get it either at the dealer or a junkyard, just make sure it's in good condition and has no cracks.
Best regards,
Oscar.
EDIT: Sorry I didn't read your first post about towing your car home, disregard anything about the bolts. Good luck!
BY THE WAY WELCOME TO THE FORUM!
Old 01-22-2011, 03:19 PM
Thanks again for the help. We it tore apart and sure enough, it was the shift tube--broken in two at the gasket. Paid $65.00 (including tax) for the new shift tube, a plunger which sits inside the tube and two new gaskets from our local Ford dealer. It took us about 2 1/2 hours to replace but that included breaks to warm our hands and the rest of us in the house.
Old 01-22-2011, 05:50 PM
way2old's Avatar
TOKEN HILLBILLY
Thanks for the fix reply. We do not get enough of those.
Old 12-24-2011, 12:47 PM
Djandreau Djandreau is offline
Hi, everyone, I have a '93 Automatic Crown Vic myself, and I am having some problems. One, I don't know how many miles the car really has, the numbers have been the same since I got it from my mother-in-law, who's son had it, and his uncle had it before him. Well, the care has been perfect till up to a month or so ago, I mean there were some problems, but I didn't think nothing of it, 'cuz it didn't act up... now its bad.
I am having the same problem, where my shift seems to be in park, but slips into neutral or reverse. I have to "slam" like stated in another post, just to make sure it is in park, but then also have to put the E-brake on(this is because, I was getting out once, and the car started rolling, and luckily I was able to jump in and slam on brake.) There's times also, where I will shift into reverse and I'm stuck in neutral, same if i go into Drive. Can I be having the same troubles as the other two?
Also, if I could maybe get some help on another problem... There are a lot of times while I am driving, that my car will sputter... like its having troubles moving forward, and during this it fights to gain speed(this is worse, when I got to make a turn into traffic or get on a main road!) I noticed a clunking sound also while it does this, and to me is seems like its fighting to shift into another gear... This is hard to explain really... but maybe you will understand. I am no good with cars, but I hope I can get some help. I also just replaced oil filter, and fuel filter, put new oil in. Checked Tranny Fluid and it looks alright. I also used some Fuel-Injector Cleaner.
Thank you.
Old 12-24-2011, 04:05 PM
olopezm's Avatar
Hi Andreau welcome to the forum!,
First of all I would advise you to use the E-brake at all times instead of putting the weight of the car on the transmission; this is not a good idea as it might cause long term damage.
If the shifting lever wobbles all the time and is hard to move, it is very likely that the Torx bolts holding the lever to the linkage are loose and need to be retightened. You need to take a look under the dashboard (remove the kick panel) while moving the lever or ask someone to do it. You will see where the problem is very easily. As stated before I think the Torx bit size is T10 or T15. Just thighten the 2 bolts and you should be good to go.
About the other problem I'm pretty sure the EGR channels are clogged. It is a common problem with 91-95 4.6L engines.
Take a look at THIS LINK
Also pay attention to a rubber tee connection the PCV valve (on top of the passenger side valve cover) to the back of the throttle body. This is another common problem on 91 to 94 and some early 95 models.
Oscar.
93 blazer transmission linkage crazycowprod Problem Diagnosis 1 08-22-2009 02:41 PM
Transmission linkage Chevynovaplanjane Nova 5 01-24-2006 10:41 PM
Transmission linkage on a 93 taurus Ironmike215 Taurus | Taurus Wagon 1 12-28-2004 01:13 PM
Manual Transmission Linkage Rattle dkstar M3 0 06-17-2004 05:40 PM
