Old 11-05-2010, 07:13 AM
bheston bheston is offline
'99 Silverado 2500 - Replace rear wheel bearing
1999 Silverado 2500 4x4 6.0L
I had a squeeking sound in the rear end, U-joints all fine, then noticed my right rear wheel had some fluid on it. I pulled the brake caliper off and it looks fine, slipped the rotor off and found fluid coming from the axle seal.
I assume I need to replace wheel bearing and seal, and the axle shaft looks like it has to come out but I haven't done one of these before. Do I have to open the differetial? What holds the axle in place? I have read that the bearing is either pressed into the axle tube or pressed onto the axle shaft, anyone know what is true? I have a slide hammer if I need to pound it out of the tube, any other specialty tools needed?
TIA guys, this site is great!
Old 11-05-2010, 09:14 AM
j cAT j cAT is offline
Re: '99 Silverado 2500 - Replace rear wheel bearing
using a repair manual open the rear diff cover. both wheels off the ground . then rotate the axle to reveal the locking hardware.
pull axles out. using a slide hammer with jaws remove the bearings/seals. not needing a lot of force.
on installing use a large socket and tap into place.
replace both at this time. not just one side.
if the brake shield is rusted out a good time to replace that as well.....
Old 11-05-2010, 01:27 PM
kahjdh's Avatar
kahjdh kahjdh is offline
do the 2500's have full or semifloating rear axles? It will be different then.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 11-09-2010, 07:13 AM
Thanks for the help guys, this job was pretty simple. Once I found and removed the C clip on the axle shaft inside the differential by sliding the axle in, the axle slid right out and the bearing and seal could be replaced.
This truck has a semi-floating rear axle.
Old 11-09-2010, 10:01 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
I recently changed the bearings and axle seals on my '95 and afterwards noticed diff fluid coming out of one side. Turns out the new seal wasn't quite big enough to provide a good interference seal with the axle tube housing...it was snug but I could remove it by hand. Rather than having to drain the diff, remove the shaft, and replace the seal again, I jacked up the one side, cleaned the tube and seal surfaces with solvent, and applied a thin coat of oil resistant silicone sealant. Pressed it back in to cure...no leaks since.
I write this so you can check that the seals are a good fit and avoid more leakage. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 11-09-2010, 02:07 PM
what can occur with old/ high mileage vehicles would be a worn spot on the axle where the seals riding surface is. using a seal that is slightly different than the OEM/or what was used last could cause this to ride on the axle area not worn. then it could also be just defective chinese crap parts..especially rubber parts...
89or90 2600i 4x4 rear wheel bearings B4 roadtrip discretegeek B-Series/Bravo/Bounty/Drifter 0 03-29-2010 08:38 AM
89or90 2600i 4x4 rear wheel bearings B4 roadtrip discretegeek B-Series/Bravo/Bounty/Drifter 0 03-29-2010 08:37 AM
replacing rear wheel bearings scarecrow0529 Metro 5 10-26-2008 11:08 AM
Need to replace rear wheel bearings FWD 1993 Stealth Spin Doctor 3000GT/Stealth 0 07-14-2008 06:35 PM
Replacing Rear Wheel Bearings rspecht 3000GT/Stealth 3 03-14-2005 05:02 PM
