Old 11-04-2010, 07:10 AM
Dobaroy Dobaroy is offline
Question Change Air Filter
Just got this 2003 Safari and would like to change the air filter so first I unclipped the front of the casing, but can't figure out how to go from there to open it
Thanks.
Old 11-06-2010, 08:01 AM
old_master's Avatar
Advisor/Moderator
Re: Change Air Filter
There are plastic tabs on the upper half of the housing at the rear, lift up on the front, pivot it up and pull forward to remove it. If you loosen the clamp on the air inlet hose, then disconnect the hose from the filter housing, it makes it a little easier.
You have to know how it works,
to figure out why it doesn't.
Old 11-06-2010, 08:16 AM
Thanks for the reply. We will try that when it warms up a bit. It is pretty cold here this morning.
Old 11-07-2010, 08:54 AM
Well that's done, hope I don't have to do that again in a hurry. Appreciate the advice, it just felt like something was going to break.
Roy
Old 11-07-2010, 01:08 PM
old_master's Avatar
Advisor/Moderator
Yup, I know whatcha mean! The rubber around the filter gets compressed by the housing. That's what makes the seal between the filter and the housing, and why it's such a tight fit.
Old 11-07-2010, 02:48 PM
danielsatur danielsatur is offline
Don't forget todo the PCV valve, and the fuel filter.
I know a dude chasing a random misfire, and spent $3.5K because of a bad fuel filter.
Old 11-14-2010, 08:09 AM
Did the PCV and fuel filter but thanks for the suggestion.
K&N Engine Air Filters - Worth It? RidingOnRailz Engineering/ Technical 9 06-24-2011 09:34 AM
changed air filter, now stalling surging at idle jsfx3 Windstar 8 03-17-2011 07:50 AM
Air Filter. Recommendations? xephornite Aveo 5 07-10-2010 05:42 PM
backfirea and caught air filter on fire!!!! davidrobert2 LeSabre 8 03-27-2009 07:22 AM
HELP! how to change air filter for 1999 neon terabreak Neon | Plymouth Neon 1 12-02-2003 12:11 PM
