Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 05-21-2003, 05:17 PM
rjbianchi rjbianchi is offline
2003 Z71 Front end low
I have an 03, Z71. The front end sits a little lower than the rear. I would like to raise it to be level to the rear. I was going to get spring spacers, but there are NO front springs.
What can I do??
Old 05-21-2003, 05:35 PM
marzo7 marzo7 is offline
Well, your truck does have front springs, they're just not coil springs. Most new 4x4's have torsion bars in front, and you can often raise the ride height an inch or so just by rotating the torsion bars in their mounts.
Sorry though, I'm not familiar with your truck so I can't provide any specifics for you.
Old 05-22-2003, 01:39 PM
Cy@tirerack Cy@tirerack is offline
If adjusting the torsion bars does not help, then you may want to consider lowering the rear.
I have customer with a 02 Z71 who just ordered Eibach 3882.520 ProKit Springs for the rear from us. There may be some customization required so I would recommend contacting Eibach Techical Support at 909.256.8300 to go over what other changes would be required.
Delivered cost on a set of springs would be about $157-$187 depending on zip code.
[email protected]
Creaking Noise At Front-End el ratfink Pacifica 2 12-05-2009 11:57 AM
Front end noise Bob Moore Dakota 5 07-25-2009 04:40 PM
Front End Metallic Clunking amesjm0431 Grand Prix 2 06-17-2009 09:17 PM
04 Z71 Front End Noise bt12rs Tahoe 3 03-02-2006 09:02 PM
99 Z71 front end seems to bouce too much.. Dakotarota Silverado 1 10-10-2003 08:09 PM
