Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 11-02-2010, 04:39 PM
pieps57 pieps57 is offline
No Heat
I purchased a 1988 toyota pick up, the heat in it does not work. The blower works on all settings but blows cold air.
Where should I start or any ideas what it is?
Thanks!
Old 11-02-2010, 05:03 PM
Scrapper Scrapper is offline
AF Premium User
Re: No Heat
i'd start by changing thermostat. and when it cools off take cap off and see if it circulating because rad may be plugged or half plugged or need new heater core? is it over heating on you or loosing antifrezze? one more thing is acculator gumbed up. dose it blow out on all vents when you change settings?
Old 11-02-2010, 05:40 PM
Re: No Heat
it does not overheat, nor do I lose antifreeze. It does blow out of all vents when settings are changed.
Old 11-02-2010, 06:38 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: No Heat
Start by checking the coolant level.
Then make sure the heater valve on the firewall moves from heat to cool as you move the control on the dash.
If all that is OK you may have a clogged heater core.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 11-03-2010, 03:29 PM
Re: No Heat
"Then make sure the heater valve on the firewall moves from heat to cool as you move the control on the dash"
How do i verify this??
Old 11-03-2010, 10:43 PM
fourwd1's Avatar
AF -Advisor
Re: No Heat
Watch the valve for movement while someone moves the lever inside back and forth.
The lever and valve are connected by a cable, sometimes either cable or valve can freeze up.
89 4Runner - stock
Old 11-04-2010, 07:18 PM
Re: No Heat
So if i open the hood I can see the valve against the firewall behind the motor?
Old 11-04-2010, 09:09 PM
fourwd1's Avatar
AF -Advisor
Re: No Heat
Yes. There are 2 heater hoses going to it.
89 4Runner - stock
96 S10 Heat always on CSR44 Blazer 3 11-04-2010 03:25 PM
Odd recurring heat problem, 2007 Impala myshoulderissore Impala | Impala SS 3 11-03-2010 06:38 PM
Manage Your Heat!!! Manage Your Heat!!! Manage Your Heat!!! Manage Your Heat!!! eahockeygod Metro 3 01-10-2005 08:00 PM
Heat then No Heat randyman C/K 3 12-11-2003 02:25 PM
