Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 11-02-2010, 10:57 AM
myshoulderissore myshoulderissore is offline
Odd recurring heat problem, 2007 Impala
We have a weird issue with our Impala currently. In the mornings, we start the car, and get no heat for 5-10 minutes, unless we rev the piss out of it while under load (driving very aggressively.) Even once the heat has started, if we don't maintain 1500+ rpm, we lose the heat, and it starts blowing cold. Below 2k rpm, it is only lukewarm. Also, as it heats initially, it goes from cold, to the middle, to almost in the red, then we get heat and it settles back down to the normal range. Last year we had a new water pump put in (due to the same issue) and the system flushed, although that only partly fixed it, and only for a couple months.
I am thinking maybe stuck thermostat and/or air in the system, but I wanted to get some opinions before hammering away at it. Thanks in advance!
Old 11-02-2010, 06:58 PM
maxwedge maxwedge is offline
A990 racer
Re: Odd recurring heat problem, 2007 Impala
Sounds likke air in the cooling system, needs to be bled, there a bleeder on the T'stat housing. warmed up, hold the engine at 1k open the bleeder, let it run oun out till no air bubbles, need lots of rags here.
Old 11-03-2010, 02:26 PM
GMCustomerService's Avatar
GMCustomerService GMCustomerService is offline
I would recommend taking the vehicle into your local dealership to be diagnosed. They should be able to assist you further and have a plan for addressing the issue. If you have further questions, please feel free to contact me directly. Thank you.
Tricia, GM Customer Service.
Old 11-03-2010, 06:38 PM
j cAT j cAT is offline
I am surprised this 3yr old vehicle has coolant issues.
what is the coolant used exactly. who maintains the coolant ?
Strange 2007 Impala LT Keyless problem Codeman96 Impala | Impala SS 10 02-19-2010 11:39 AM
1994 voyager ac and heat problems bitco Caravan | Voyager 2 10-20-2009 08:49 AM
'04 Impala Heating problems 20impala04 Impala | Impala SS 1 09-19-2007 03:37 PM
Odd, Odd Dash/Electrical Problem lpradiohead SC/SL/SW 3 01-03-2005 11:45 AM
recurring overheat problem rodneyd Durango 1 11-25-2004 02:01 PM
