Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 10-11-2001, 09:22 PM
vikon vikon is offline
Question Idles rough in reverse gear
Hello,
It is an automatic 1996 G20 , 90K miles...I had just recently tuned it up....changed everything (filters, spark plugs, wires, cap and rotor)...the transmission fluid also has been flushed and the filter replaced...I brought it to a transmission shop, and they've told me the transmission is good...
I've just noticed that when the car engages in reverse it idles very rough, however drives fine. I don' think it did that before. Does anybody know what could cause the rough idle in reverse? It idles fine in other gears.
Thanks in advance!
Regards,
Viktor
Old 10-12-2001, 06:17 AM
It feels like the car with a manual tranny about to stall, because the clutch pedal is not pressed, except it doesn't stall and the idle stays steady.
Thanks!
Old 10-12-2001, 04:01 PM
T4 Primera T4 Primera is offline
Check your engine mounts in case the rough idle is really the engine shaking around on broken mount/s.
This is a real longshot but ... try pulling the reversing lights fuse and see if your problem still exists. If it goes away, you may have a short between that circuit and something else like ignition circuits etc.
"The cause of liberty becomes a mockery if the price to be paid is the
wholesale destruction of those who are to enjoy liberty."
-- Mohandas Karamchand Gandhi
"They that can give up essential liberty to obtain a little temporary safety
deserve neither liberty nor safety."
-- Benjamin Franklin
"The biggest cause of trouble in the world today is that the stupid people are
so sure about things and the intelligent folks are so full of doubts."
-- Bertrand Russell
Old 10-12-2001, 06:52 PM
Thanks for the info...I have a question though...If the engine mounts are bad, wouldn't it vibrate the whole time? And, what causes the mounts to go bad? 90 K miles - isn't kind of early?
Thanks in advance!
Regards, Viktor
Old 10-12-2001, 09:18 PM
I don't know if it has anything to do with it but I forgot to mention...the car battery seems to be in bad shape...It had a lot of build up on it and I cleaned but...Could the battery cause this? It seems like it started to shake in reverse after I tuned the car up...Here is what I replaced:
1. PCV valve;
2. Fuel filter;
3. Wires - NGK;
4. Plugs - NGK;
5. Distributor cap;
6. Distributor rotor;
7. Air filter;
8. Oil filter with oil change +Slick50;
9. Valvoline SynPower Fuel system treatment;
10. Cleaned the battery terminals...
Any ideas????
Old 10-12-2001, 10:02 PM
Thanks in advance!
Regards, Viktor
I suggested engine mounts because when in reverse the axles apply a torque to the engine/tranny in the opposite direction - so the engine mounts will be loaded differently.
I don't see anything in your list that is likely to have caused this. I'll have a look through my Haynes manual after work and get back to you.
Originally posted by vikon It feels like the car with a manual tranny about to stall, because the clutch pedal is not pressed, except it doesn't stall and the idle stays steady.
Do you mean it lurches when you are reversing like a person trying to learn how to drive a stick? Is the idle problem only when you are moving in reverse or when stationary with reverse selected?
-- Bertrand Russell
Old 10-13-2001, 01:06 PM
the same kind of vibration...the RPM stays steady though and the engine doesn't stall...
you can feel the vibration mostly when stationary with reverse selected, and it eases out when you start moving, so I guess I can say that it vibrates only when stationary...
I had a transmission guy looking at it this morning, and he said that it's an engine mount, and it's nothing to be concerned about unless it goes really bad...So I guess it has nothing to do with the idle itself...
Thanks for your reply!
Regards,
Viktor
Old 10-14-2001, 04:55 AM
Once one mount fails the others have to take up the extra strain and eventually they may all fail. Also if your engine is moving around more than it should it may be stressing other things like your exhaust system etc. Also I've heard that the transmission casings are prone to cracking even with good mounts so ...
It definitely isn't anything to panick about, but still, it just ain't right. Glad it wasn't anything more serious.
-- Bertrand Russell
Old 10-14-2001, 06:58 AM
How much would it cost approximately to replace a mount? I know that the part itself isn't cheap ($50-$150)...It must be a lot of labor on top of that...Any ideas?
Thanks!
Old 10-14-2001, 08:08 AM
My Haynes manual only mentions 4 mounts. One on the pulley end of the motor, one at the rear of the engine/transmission, one on the front of the engine and one on the tranny. If you have a good look around you'll find them but you might need to get underneath to see them.
Look for black liquid leaking from them or torn rubber. Check also that the bracket bolts haven't worked themselves loose
No idea on replacement costs. A good one from the junkyard might be a better cheaper option. You'd be very unlucky if you had to replace all three.
Labour is not much compared to some things but if your handy you could do it yourself.
It really isn't an urgent problem though so take your time.
-- Bertrand Russell
Old 10-14-2001, 08:49 AM
Thanks so much for your input!!! I'm so glad I found this forum...I've been posting my questions on a newsgroup previously (alt.autos.nissan), and I haven't had a good experience with it. I also have a 1987 Nissan Pulsar NX, and have posted questions about that car...Basically, no input on neither of these cars..
Thanks again!
Regards,
Viktor
Old 10-14-2001, 03:47 PM
Vikon,
Check out this related thread:
http://www.automotiveforums.com/vbulletin/t7712.html
-- Bertrand Russell
