Old 10-31-2010, 09:50 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Clockspring gone bad?
Today the airbag diagnostic light at the instrument cluster came on and stayed on showing code 32, this has happened before but it suddenly stopped and everything was working fine.
The problem is that now the horn doesn't works so... do you guys think the clockspring is bad or could it be a wiring problem?. Thanks in advance...
Best regards,
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 11-01-2010, 08:56 AM
12Ounce 12Ounce is offline
Re: Clockspring gone bad?
They do fail. I'm on my second one, and it is now suspect. 300k miles. I wish I had kept my original .... as it may be repairable. Nothing but a couple of wraps of multi-conductor flat cable. If you remove this gadget, be sure to fastened the steering column in some way so that you have the correct "starting point". The clockspring has to be set up so that it does not get damaged as the wheels are turned lock-to-lock.
Old 11-01-2010, 11:11 AM
olopezm's Avatar
Thanks 12Ounce, I tried to remove the air bag module but I couldn't see how it comes out is it held by the two small nuts which can bee seen to the sides of the connectors inside the steering wheel?.
I would like to know more about the multi-conductor cable fix in case my clockspring is repairable. Thanks
Best regards,
Oscar.
Old 11-01-2010, 04:58 PM
I was a long time ago when I replaced the "clockspring" ... so I don't remember the small details. I do remember I bought the new clockspring before beginning ... once seeing the details of the new spring, I was tempted to try a repair. I haven't actually tried the repair ... it may be more difficult than I'm thinking.
Old 11-03-2010, 07:17 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
I was told that I would have to replace the clock spring on my 98 because they fail after the airbag deploys. I checked the condition of the CS with an ohm meter. It was fine. I've heard that the airbag SHOULD NOT be tested with a meter because it might go off.
I guess this really doesn't answer your question.
Off hand I don't remember how to remove the AB.
Dan
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
throttle body cleaning gone bad on a Del Sol 1.6 SOHC KrazyGoku '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 04-06-2002 05:34 PM
Axle gone bad? Hybrid Boy Engineering/ Technical 1 02-04-2002 11:52 PM
Axle gone bad??? Hybrid Boy '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 10 02-04-2002 08:02 AM
oxygen sensor gone bad? kidrocket Engineering/ Technical 2 02-01-2002 05:01 PM
A little off topic: State Safety Inspection Gone Bad! Help! GL7043 Eastern US 5 12-21-2001 11:58 PM
Tags
airbag , clockspring , code , horn
