Old 02-03-2002, 01:17 PM
Hybrid Boy's Avatar
Hybrid Boy Hybrid Boy is offline
Banned
Send a message via AIM to Hybrid Boy
Axle gone bad???
Ok, I think I told you all earlier when I got my swap done, since I have dx hubs, the shop had to POUND in(force) the axles. For about one month and a half, I had no probs at all. Now whenever i turn left, and accel med-full i feel a "clunk" and I swear its my left axle. I am guessing since I dont have the ex suspension, and they had to force in the axle, it caused the axle to go bad. So do you think its the axle, or what else could it be? So should I now go out and buy a used ex suspension and get that fixed? Thanks
Old 02-03-2002, 01:55 PM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
I think it probably is the axel since they forced it in. Why did they do that anyways? I remember a clunk when i did my motor swap and it ended up being my axel/cv joint had gone bad. i would check it out since they "pounded it in" and all.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 02-03-2002, 02:13 PM
Hybrid Boy's Avatar
Banned
itys because i have a dx, and the hubs are smaller than the integra axle. if i get the ex suspension, which is spendy, the teg axles wont have to be forced in since they would fit....
Old 02-03-2002, 05:10 PM
pvang31019 pvang31019 is offline
Its probably your outer cv joint....call me up and I'll take a look at it. I can probably take off the knuckle and press in a new hub/spindle assembly....
Old 02-03-2002, 08:25 PM
CivicOwnage CivicOwnage is offline
what do you meen by clunk? do you meen it souns like a rock in a metal can bouncing around? cause i hav that too and its not just one clunk it keeps doing till i stop turning left.
Old 02-03-2002, 08:47 PM
sparq's Avatar
sparq sparq is offline
AF Premium User
Send a message via AIM to sparq
No, the noise you are describing is your CV joint... the noise "Hybrid Boy" is talking about is most likely the axle...
AF's Official Asshole
RIP AUNIE
Old 02-03-2002, 08:59 PM
are cv joints expensive to fix?
Old 02-03-2002, 09:29 PM
90CRXZCSi's Avatar
CV Joints dont run much at all. They are like $69 for the left and like $59 for the right. That reason is because the left side is bigger than the right.
Old 02-03-2002, 09:40 PM
thats good to know, hey 90crx i live in colorado too, and i was also wondering if you knew any cheap shops here, cause the shop i go to charges just 50 bucks for diagnostics and its a little expensive, you know any independent shops that do a good job for a reasonable price?
also is it posible to change the cv joint myself? anyone have instrunctions or anything?
Old 02-03-2002, 09:48 PM
actually, not that I think about it, it might be the inner u-joint....but it should only happen while going straight....
Old 02-04-2002, 08:02 AM
Hybrid Boy's Avatar
Banned
it happens while going strait from a hard launch sometimes too....
Warning: Shaved Door Handles Gone Bad wagsaccordsir Accord/TSX/Accord Hybrid 2 07-18-2007 10:47 PM
throttle body cleaning gone bad on a Del Sol 1.6 SOHC KrazyGoku '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 04-06-2002 05:34 PM
Axle gone bad? Hybrid Boy Engineering/ Technical 1 02-04-2002 11:52 PM
oxygen sensor gone bad? kidrocket Engineering/ Technical 2 02-01-2002 05:01 PM
A little off topic: State Safety Inspection Gone Bad! Help! GL7043 Eastern US 5 12-21-2001 11:58 PM
