'98 1T brake line replacement/repair?
My '98 1 Ton has blown the rear brake hose that is mounted inside the frame behind the fuel tank. This hose is wrapped in electrical tape, and looks to have been replaced with a longer one. Can anyone advise what is supposed to be there, or the correct length of hose to replace it. Also, what's the easiest way to replace it? Not much room to work in there! Wrench sizes? Shouldn't this be a steel line?
Stale Trooper '05 CVPI (My '99 got wiped out with 238,513 miles on the clock, stupid woman driver) It's White, with a black grille, a spotlight, and the butt is black. Need a picture? Thought not
Re: '98 1T brake line replacement/repair?
Since it's something as critical as brakes, a trip to your local dealer should get you what came on the truck new.
1992 Bravada, 201K, stock 1997 Bravada, 101K, stock...was "called away" ![]() "Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14 ![]() Time to turn so's you don't burn.
