Old 10-29-2010, 10:09 AM
JustinAH91 JustinAH91 is offline
Nasty Vibration 30-35mph
Title pretty much says it. I checked for play in the wheels and nothing seems out of the ordinary. Thought maybe a tie rod end on the front wheels but not sure.
Anyone have an idea why my s10 would only vibrate and rumble between 30-35mph? It is only 30-35mph that it does this...
Any advice is welcome!
Car info: 1999 s10 pickup LS extended cab, 2.2l 4 cyl automatic. 200,000 miles.
Old 10-29-2010, 10:46 AM
laxman21's Avatar
laxman21 laxman21 is offline
Re: Nasty Vibration 30-35mph
Universal joint worn out.
If your drive shaft is 2 piece and has a carrier bearing, it could be worn out.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 10-29-2010, 02:42 PM
We replaced the ujoints and the rear end was recently replaced as well...could it be anything else?
Old 10-30-2010, 02:11 AM
viggy58 viggy58 is offline
was the drive shaft replaced with the rear end? i'm not sure, but it may need to be balanced? or maybe the bearing thing mentioned above.
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Old 10-30-2010, 08:21 AM
We figured it out. The stupid mechanic we took it to to actually put the ujoint in since we couldn't get it hot enough to melt the nylon crap out did not put the two addition c-clips on the other two caps, so the caps are on but they're loose! ugh. Went and bought another ujoint to replace the caps c-clips.
1990 right front driveline vibration dieter LeSabre 2 04-04-2009 09:16 PM
noise /vibration 30/40 mph sick96 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 03-16-2009 11:44 AM
stalling around 30-35mph pointA2B101 Century 1 07-27-2006 07:52 AM
Hesitant on starting and 30- 35mph valegirl98 Grand Cherokee | Grand Cherokee SRT8 1 07-16-2004 02:31 PM
