Old 08-19-2006, 07:36 AM
Scottsarah Scottsarah is offline
2001 Town & Country cooling fan Relay
Could someone please tell me where the cooling fan relay is?
My 2 fans that cool the the radiator stopped working.
Old 08-19-2006, 08:03 AM
Bear Bear is offline
Re: 2001 Town & Country cooling fan Relay
There should be a location listed in owners manual, also there are fuses in the Power Distribution Box (under hood) for the fan and also a temp sensor in block ( right at the thermostat housing) that controls the fans. You can disconnect the electrical lead at the fan and run a wire from + terminal plus a ground wire,on battery to the fan electrical connection (on fan) and see if the fans run (isolating the motor as a problem)
Old 08-19-2006, 08:16 AM
yes I saw the box under the hood but it doesnt specify which relay is for the cooling fans??
Old 08-19-2006, 08:53 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
You will find it on front bumper reinforcement behind grille.
Left lower on frame beside radiator.
It is in a small type transister box.
Go to the dealer and pick one up to see what it looks like and check for recall on it.
Also check fuse no 27 a 40 amp fuse in engine compartment.
MT
MT
