Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 10-28-2010, 04:45 PM
waterkeeper03 waterkeeper03 is offline
Working it out
3rd time replacing the Blower Motor Relay
2004 Impala 3.4
10 speed fan
it's good for about a month, then shorts out again.
first time I had only low speed fan.
next time I had to remove the relay to shut off the fan
this time I have no fan at all
It was suggested that maybe I need to replace the control unit for the ac (where I adjust the fan speed and temp)
any ideas?
Old 10-31-2010, 08:29 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 3rd time replacing the Blower Motor Relay
You might want to check the blower motor.
Check for ground and amp draw on the blower motor.
Does the havc ever set any body computer/havc codes?
MT
Old 11-09-2010, 04:09 PM
Working it out
it has never thrown any kind of codes. I will go have the motor tested, is is better to just take the motor out and to a shop, or to take the whole car??
I'm not going to pay them to trouble shoot this whole thing
Old 11-09-2010, 04:28 PM
inafogg inafogg is offline
i'v seen where the motors were blowing resistors but on dodge/chry
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 11-09-2010, 04:46 PM
MT-2500's Avatar
AF - Advisor
Was the Havc/body computer checked with a Havc/body capable scanner?
Or did you just look for OBD11 codes?
Take the whole car to them.
MT
Old 11-21-2010, 06:45 PM
Jerk of all trades Jerk of all trades is offline
Have you changed out the cabin air filter yet?
Old 11-27-2010, 09:40 AM
Working it out
I have not scanned it for anything, there isn't any sign that there is a code being thrown. but i have a friend with an obd11 scanner, don't know if it's body/hvac capable
I didn't even know there was one untill you said that. it's under the black plastic cowl cover under the hood?
Old 11-27-2010, 12:41 PM
MT-2500's Avatar
AF - Advisor
I would be checking the amp draw on fan motor.
If you get any Body/Havc computer codes post back code no and amp draw.
MT
1996 Explorer with blower motor issues CREESERFARM Explorer | Explorer Sport Trac 13 02-03-2011 01:13 PM
Where is the Blower Motor Relay / Blower Resistor located Cavycare Cavalier Problem Diagnosis 3 02-13-2007 07:22 PM
94 Quest, Front Blower Motor Relay Location mdion Quest | Presage | Serena 3 11-02-2005 08:30 PM
How to replace the blower motor on 93 nuts n bolts Intrepid 5 02-05-2005 07:37 AM
Need some wiring schmatics for the Blower motor and relays for it... Opps123 Park Avenue 0 09-11-2003 10:31 PM
