Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-27-2010, 09:49 PM
1997 eclipse 4g63 1997 eclipse 4g63 is offline
high boost Q&A
Hey I'm new in this forum but I'm really needing some help please could someone out there tell me what exsactly it means to get an eclipse motor o-ringed, how much it should cost me and if its really nessasary it running about 32psi
Old 10-28-2010, 06:37 AM
shorod's Avatar
shorod shorod is online now
SHO No Mo
Re: high boost Q&A
I moved your thread to the Eclipse forum since your question is very vehicle-specific and didn't really belong in the Engineering & Technical forum. You should get better responses here.
-Rod
Old 10-28-2010, 07:19 PM
534BC 534BC is offline
Re: high boost Q&A
O-ring installs a SS o-ring on the deck surface of the block to seal high pressures. If the engine is known for head gaskets blowing then o-ringing it will help. Many times "o-ring gaskets" are available for popular engines.
I remember getting v-8 and v-12 done for $125-$250 , I would think that maybe $20-40 per hole might be a fair price today.
Old 10-28-2010, 09:31 PM
ned032002's Avatar
ned032002 ned032002 is offline
Re: high boost Q&A
Why do you ask?
Old 10-29-2010, 02:09 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: high boost Q&A
Im going to assume we are talking about a 4g63 7bolt motor. You dont need to oring the motor. Before you start talking about running 30+psi what kind of mods are you working with right now. You cant just crank up the boost and expect to make power. Boost pressure is really irrelevant, you should set a power goal to reach and then adjust boost accordingly. Say if you want 400whp then you size your turbo accordingly. Then turn up the boost till you reach that goal.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
high boost application DeleriousZ Forced Induction 12 03-03-2004 05:28 PM
info on h22a buildup for high boost 8urdomestic Forced Induction 6 01-06-2004 10:00 AM
prepping for high boost. 93civic$racer Forced Induction 18 12-11-2003 10:56 PM
High Boost DarkAccord600 Accord/TSX/Accord Hybrid 2 09-01-2003 03:21 PM
Eagle or Crower Rods for High Boost from Turbo compwc18 Engineering/ Technical 0 12-01-2002 04:27 PM
