Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 10-26-2010, 04:01 PM
freesoul freesoul is offline
91 Suburban dash brake light on
Greets, as the title implies. Before the light came on the truck had a propensity to lock up the back wheels, other than that it seemed to work fine. The light stays on dimmer than when the e-brake is applied. Brake fluid level seems fine.
I am trying to narrow down what could be the culprit- master cyl, proportioning valve, ????
I am selling this truck and don't want to put a lot of money out but I want to fix it first.
Thanks in advance!!
Old 10-26-2010, 04:07 PM
old_master's Avatar
Advisor/Moderator
Re: 91 Suburban dash brake light on
On the prop valve there is an eclectrcal connector with one wire in it: Unplug the connector and see if the red "BRAKE" indicator on the dash goes out. Post your results.
You have to know how it works,
to figure out why it doesn't.
Old 10-27-2010, 03:46 PM
I an assuming this valve is located on the front of the master cylinder? If so I unplugged the wire and the brake light stays on.
thanks for your help!
Old 10-27-2010, 04:22 PM
old_master's Avatar
Advisor/Moderator
Two brake lines leave the master cylinder and go to the proportioning valve. It is usually close to the master cylinder and has 2 lines that go to the front wheels and one that goes to the rear wheels. When you unplug the wire, if the light stays on, the problem is the parking brake is not released, or the park brake switch is stuck. You can confirm that by unplugging the switch on the park brake mechanism.
Old 10-28-2010, 05:05 PM
I doubted it was the ebrake switch because when that is engaged the light is brighter. I unplugged it anyways and the light stays on dimly.
Here is a photo of what I think is the proportioning valve attached to the master cylinder. I unplugged the wire going to it and the light stays lit.
I guess I need to pull the rear drums and see whats going on.
Old 10-28-2010, 06:29 PM
old_master's Avatar
Advisor/Moderator
Yes, that is the proportioning valve. If it stays lit when both the prop valve and park brake are unplugged at the same time, there might be a problem in the daytime running light circuit, (the DRL's use the same tan with white trace wire). Check the fuses and DRL bulbs and grounds.
Old 10-28-2010, 07:19 PM
I don't think this truck has daytime running lights, also like I mentioned before there was a problem with the rear wheels locking up that has not occured since the light came on. Ugh, I just need to sell this thing and was hoping to fix the dash light before that happened so I can get the most for it....
Old 10-28-2010, 07:23 PM
old_master's Avatar
Advisor/Moderator
If the light stays on with both the park brake switch and prop valve unplugged, the brakes are not causing the light to come on. Those are the only two things in the brake system that can turn the light on.
Old 10-29-2010, 12:33 PM
Ok, so then it points to an electrical fault somewhere? Its just odd that the speedometer failed and this light started being on at the same time.
Old 10-29-2010, 02:50 PM
old_master's Avatar
Advisor/Moderator
Bingo! Most likely a poor ground or short circuit in the cluster itself or the wiring that goes to it. Make sure the connector that plugs into the instrument cluster is plugged in tightly. It's kind of a cheesy set up and can vibrate loose over time. Check all fuses, both terminals, with a voltmeter or test light.
Old 10-29-2010, 07:03 PM
777stickman 777stickman is offline
Not real sure if your '91 has rear ABS. If it does and the speedo quit, you may want to look at the VSS (Vehicle Speed Sensor).
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
2004 Sentra 1.8S-No brake lights?!? brynfrt05 Sentra | 200SX (USDM FWD) 11 06-08-2010 09:30 AM
1999 Passat - Changing Brake light bumpsetspikeki11 '97+ 0 03-09-2010 07:38 PM
emergency brake light comes on freakyfire05 ZX2 8 02-11-2010 10:19 AM
Brake Light Switch uspres2020 Escort 5 09-28-2009 12:11 AM
Brake lights problem corollastudent Corolla/Matrix/Voltz 1 07-20-2009 12:39 PM
