Old 10-26-2010, 03:26 PM
jeffro6770 jeffro6770 is offline
98 Lumina crank no start
I have a 98 Lumina with a 3.1L in it. I removed intake manifold and replaced gasket for water leak. When I put it back together I have no spark now. Engine will crank but no spark until you let key go back then it gives a spark. I have had ignition module checked at autozone and they say it is good. I have checked several times and made sure every thing I disconnected is hooked back up again. It ran when I pulled it into the garage. Any help where to check next.
Old 10-26-2010, 06:53 PM
maxwedge maxwedge is offline
A990 racer
Re: 98 Lumina crank no start
Make sure you have 12v to the pink wire at the icm, when the key is on.
Old 10-26-2010, 08:53 PM
Yes, there is 12v at pink wire with key on. I also checked and made sure all fuses are good.
Old 10-27-2010, 08:00 AM
A990 racer
If it ran before keep searching, something occurred during the reassembly.
Old 10-30-2010, 03:12 AM
Bearwulf's Avatar
Bearwulf Bearwulf is offline
Make sure that starter is wired correctly, sounds like wire loose or bad solenoid.
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
Old 10-30-2010, 01:31 PM
A990 racer
Question Re: 98 Lumina crank no start
How does this affect no spark?
Old 10-31-2010, 11:50 AM
Thanks for the help. I have found my problem. Somehow the icm has taken a shit. Replaced and car runs now. Unfortunatly it has more problems now. Not sure how long it was run with water in the oil. Seems that oil pump is bad and not pumping oil thus starving upper half of motor. Very noisy.
1998 lumina ltz starting problems luminakid1992 Lumina 17 05-22-2011 10:55 PM
Will not start (sort-of randomly) caffeineaholic Caprice 7 08-04-2010 08:13 PM
1990 lumina won't start w/new cps/ign mod carkid7 Lumina 1 07-30-2010 11:42 AM
92 Lumina Won't Start ICM Voltage Brndo Lumina 9 05-02-2010 11:37 PM
1998 Express Cranks but no Start kmckev2 Express | G Van 5 01-07-2010 11:26 AM
