Go Back   Automotive Forums Car Chat > Chevrolet > Express | G Van
Old 10-25-2009, 06:36 PM
kmckev2 kmckev2 is offline
Exclamation 1998 Express Cranks but no Start
Hey yall,
I have a 1998 3500 5.7l Express, I parked it the other night and in the morning it would crank but won't start.
Has Spark
Replaced Fuel Filter.
I tested the fuel pressure and it jumps right to 60 psi.
I replaced the Crank sensor, cam sensor and distributor rotor.
I've tried to spray starter fluid down the intake and it has no effect.
Shows no codes on reader.
While cranking it sometimes will "kickback" or burp out vapor and air from the intake manifold out through the airbox.
Distributor rotor does turn while cranking, ruling out the timing chain?
If anybody has any ideas they'd be greatly appreciated, this one has me really stumped
Thanks, Kevin
Old 10-25-2009, 07:25 PM
rhandwor rhandwor is offline
Re: 1998 Express Cranks but no Start
I would suspect a stretched timing chain. Rotate it by hand appx. 60 degrees past top dead center. Rotate it back to TDC remove the distributor cap use white out and mark rotor tip. Then roll the engine by hand until the rotor just starts to move. If your much past 20 degrees the chain is stretched.
Old 10-25-2009, 08:15 PM
Thanks alot,
Sounds like a plan, I'll try it tomorrow and post back the results.
Old 10-26-2009, 09:27 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Also confirm good hot spark to all plugs.
And good fuel pressure.
You need 64-65 lbs of fuel pressure engiune cranking on a cold start to squirt injectors.
MT
Old 01-07-2010, 10:36 AM
razeontherock razeontherock is offline
How long is the timing chain in the vortec engine typically good for?
Old 01-07-2010, 11:26 AM
MT-2500's Avatar
AF - Advisor
To save on high jacking post fees.
Best to start a new Tread on that and give all info.
Year make and model and engine and mileage.
MT
Tags
crank , distributor , express , sensor , start
