Old 10-26-2010, 10:56 AM
mikeso_81 mikeso_81 is offline
Blower Switch
Hi,
When I turn my heat or ac on, the blower switch only works on 3, 4, or 5. For some reason, setting 1 or 2 does not work. Is the switch bad or something else? Any ideas?
2001 Pontiac Grand Prix GT 3.8
Thx
Old 10-26-2010, 04:33 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: Blower Switch
Is you have a manual control your blower motor resistor might be on it's way out, when it goes bad the motor will only work at the highest speed. It is located on the blower motor right under the dash at the passenger side, it is adviced to take out the passenger seat in order to make more room to work.
Best regards,
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 10-26-2010, 05:46 PM
doctorhrdware doctorhrdware is offline
Re: Blower Switch
When the resistor on my 97 GP SE went out it lost 1 and 2 first. I bought the first replacement from GM first, then it went out again. So I bought the second resistor from Advanced auto. It was an exact replacement. But the motor lead on the first resistor that I bought from a Pontiac dealer was too short. One thing I would do is to remove the passenger front seat it will make it much easier to replace the blower motor resistor.
Old 10-26-2010, 06:33 PM
Re: Blower Switch
Could it possibly be the control switch itself that went bad? I was originally going to just replace the switch but noticed that 97-00 and 01-03 have slightly different panels. The 01-03 do not sell a replacement and I do not want to just start replacing parts.
I was reading somewhere online that it could be the ignition switch?
Old 10-26-2010, 08:21 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
Re: Blower Switch
The blower motor resistor is a very common problem on the 97-03 GP's and I would be willing to bet it is your problem. Classic symptoms of a bad resistor. As suggested, change the resistor. I wouldn't jump into something as big/expensive as the ignition harness right away, even though it is another common problem on the 97-03 GP.
Old 11-01-2010, 11:31 PM
Re: Blower Switch
I just replaced the resistor today and now my 1 and 2 settings work. Replacing the piece was not an easy job but I got it done. Thank you everybody for your assistance.
Old 11-01-2010, 11:42 PM
Re: Blower Switch
Thanks for letting us know that you got your problem fixed.
06 escape blower fan switch milo42gpw Escape | Maverick | Escape Hybrid 1 03-26-2009 06:38 PM
No rear defrost or lights for the temp switch,blower switch,location switch? Brian03ZX2 ZX2 2 01-08-2005 12:14 AM
a/c blower switch or blower motor? Aggrev8ed GTP Ownr Grand Prix 5 06-28-2004 10:35 PM
blower switch siminsez01 Wrangler 1 08-04-2003 06:03 PM
Blower Switch went bad ---- ideas? northwestrally Maintenance 4 05-24-2002 02:09 AM
