Go Back   Automotive Forums Car Chat > Buick > Regal
Old 10-23-2010, 10:01 AM
outlaw17 outlaw17 is offline
ABS light comes on but no codes
I have a friend with a 99 Regal LS that had the ABS light on full time, I scanned it with a Snap-on Modus scanner found 3 codes all for RF sensor. Once I checked it out I found the connector torn right off so a new hub was installed,and codes were cleared, as soon as the the car was started the ABS light was off but when driven a couple feet it was back on, I then scanned it again and there are no codes present. If the car sits with the ignition off for a long period (overnight) once started the light is off but when moved it comes on. I had the scanner connected and drove the car and it shows that all the wheel sensors are working and pretty much the same except at the initial point of movement they are jumbled but once rolling they match up . Does anyone know why this light is still coming on ?
Old 10-24-2010, 07:28 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: ABS light comes on but no codes
Is the Snap On Modus scanner fully ABS capable to include pulling GM/Bosch ABS codes?
Since the ABS light is turning on while moving it is failing the second part of ABS initialization. Do you ever get a TRAC OFF light?
Timeslip 08/12/06
AF Community Guidelines
Old 10-24-2010, 09:47 AM
I would think it would be able to, but I'm not 100% certain. Yes the TRAC OFf light is on , as well as another one , I think its SERVICE VEHICLE.
Old 10-24-2010, 10:33 AM
BNaylor's Avatar
The Snap-On Modis scan tool should if it has the right software package. For sure version 10.4 has GM ABS diagnostics capability but ouch expensive stuff.
With those lights on an ABS related DTC(s) has to be stored. Does the steering feel normal? You should have the Magnasteer variable effort ratio steering and an ABS fault will cause it to act up or be stiffer than it should.
Are you sure all wheel sensors and the connections are good? Another issue with GM ABS systems is the EBTCM module if previous possibilities is verified good. It is the module located on the front of the ABS modulator/motorpack assembly where the big electrical connector is located. The EBTCM module also controls the Magnasteer.
Timeslip 08/12/06
Old 10-25-2010, 08:56 PM
stripe stripe is offline
You may want to look at the wheel with the new hub.
If you never got it in the groove right it may have broken again.
Cheers
Stripe
Old 10-26-2010, 05:39 PM
When I first scanned it I took it for a spin and it showed no value on the RF so I knew something was wrong , once I replaced the hub with sensor now it shows the same value as the other 3 when rolling so I would think it is in properly.
Old 10-26-2010, 05:41 PM
BNaylor , the steering does seem fine , doesn't seem stiff , feels normal.
ABS light comes on after driving awhile cebryant Windstar 4 12-16-2020 12:21 PM
98 bleeding brakes/ABS light comes on PHXAuto Intrigue 2 09-28-2009 08:51 AM
2002 abs light comes on and off dan_86surb S-10 1 04-19-2004 02:06 PM
2001 sunfire abs light comes on tomgr General Discussions 7 03-18-2004 01:56 AM
ABS light comes on only after driving born2speed Integra 1 08-09-2002 04:41 PM
