Old 10-22-2010, 09:15 PM
racerxj2 racerxj2 is offline
help.. wont start 96 sunfire
replaced fuel injector o rings an did a brake job today on a 96 sunfire.. put all sensors an everything back into place but made a mistake an accidently left the spark plug wires off while tryin to start..flooded engine.. let sit an took out relay.. got it to start until all fuel was out of engine.. put relay back in an now it looks like im gettin to much fuel... any help will be appreciated.. possibly fuel pressure regulator ?? faulty relay?
Old 10-22-2010, 09:21 PM
danielsatur danielsatur is offline
Re: help.. wont start 96 sunfire
What makes you think, it's getting too much fuel!
1) Turn the key to the on pos, but don't start engine, the fuel regulator will turn the fuel pump off, after a few seconds.
Old 10-23-2010, 01:59 AM
it feels like that its getting to much fuel an not allowing it to start plus its pushing it out the exhaust manifold..
Old 10-23-2010, 02:17 AM
Is the fuel regulator connected?
Old 10-23-2010, 01:43 PM
Helmuth48's Avatar
Helmuth48 Helmuth48 is offline
Not sure if this is your problem...but I tried to replace my o-rings on my injectors..'96 2.2 Used GM, Aftermarket...and they all leaked, sometime outside the engine and worse..inside the engine...dumping fuel into the cylinders...I finally had to replace all of them...with NEW injectors...about 75.00 each !!!!!!
Some people told me they replace them NO issue....but NO not me !!!!
Old 10-23-2010, 04:10 PM
A local diesel shop could micro bath, clean, test the flow rate, and put new
injector seals for $20 each.
The fuel regular wouldn't not stop, because of the fuel leaks.
96 Sunfire won't start jkozie2001 General Discussion 0 03-07-2010 04:42 PM
1991 wont start..motor from 1985 no spark HELP rwoodxtreme C/K 4 01-31-2010 10:19 AM
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 06:00 PM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 06:44 PM
03 Eclipse rs wont start mrcontreras Eclipse 2000+ 1 02-27-2009 05:49 PM
