Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 10-22-2010, 04:00 PM
2005chevimpala's Avatar
2005chevimpala 2005chevimpala is offline
stripped spark plug
change my plugs and wires on my 3400 impala,the plug in the middle front is stripped a little,it goes tight but still spins around not going completely tight like the other plugs ,the car is running fine but is there a quick fix to make it seat tighter,what about lock tight on the threads,the plug with the wire off is not that loose that you can wiggle it but was wondering if anyone knew of a quick fix instead of having to tap it or can you buy something to go over the plug then screw it back in,thanks
Old 10-22-2010, 08:33 PM
danielsatur danielsatur is offline
Re: stripped spark plug
Did you remove the plugs, when the heads were hot?
Old 10-22-2010, 09:35 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
You are probably looking at a thread repair very soon. It's no big deal at all with the right kit.
Look here:
http://www.popularmechanics.com/cars...repair/4212608
Old 11-11-2010, 05:43 PM
Look here:
Yes the kit worked fine,took about an hour to do it but so far so good
Old 11-11-2010, 06:19 PM
Scrapper Scrapper is offline
AF Premium User
yes you can put a helia coil in it if you haven't already?
spark plugs freakyfire05 ZX2 2 02-17-2009 11:03 AM
stripped spark plug threads! XGamesJ6 Cutlass Series 7 06-13-2006 07:06 PM
stripped spark plug cordio13 Rodeo | Passport | MU 8 09-13-2005 09:06 AM
Stripped spark plug thread rmcilvaine Aurora 2 09-01-2005 02:57 PM
4.6L V8 Stripped Spark Plug Hole jeff_h Mustang Talk 2 08-28-2003 05:26 PM
