Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 10-17-2010, 03:31 PM
NBill NBill is offline
Leaking brake line
95 Sable, the brake line squirts fluid out the leak is under drivers side passenger door. Looks like a rusted pinhole in the line.
Can this be fixed and how difficult is it? Does the whole line have to be replaced?
Old 10-18-2010, 09:40 AM
65comet's Avatar
65comet 65comet is offline
Re: Leaking brake line
If you have clean, rust-free line on both sides of the hole, then a short repair line CAN be put in place with compression fittings. I say CAN because I don't recommend it. It would be something I'd do just to get the car home and then replace the entire line, and only for the back brakes since they usually use a lower pressure than the front. If the hole isn't from a visible rub spot or impact from road debris, then the whole line is probably rotting out and should be replaced.
Old 09-20-2011, 09:46 PM
jmas jmas is offline
Don't use Compression Fittings. If you must replace a section of brake line, do it with Flair Fittings.
Replacing Leaking Brake Line & Bleeding System! 1995VaFordCrownVic Crown Victoria 1 11-27-2007 09:33 PM
Camry 90 Noisy Weak Front Brakes,Leaking Brake Line Thaqalain Camry/Camry Hybrid/Vista 9 08-29-2005 06:24 PM
Oil Pan Leak repair and brake lines muddler Crown Victoria 3 07-08-2005 04:13 PM
92 maxima brake line leak jamey666 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 09-23-2004 07:38 PM
