Old 10-15-2010, 06:05 PM
cirkus cirkus is offline
Help!!!!! civic wont start help asap plz!!!
ok well i found some oil in my radiator resivior but the guy i bought it from said they did a valve job and a timing belt ive got oil in the 2 left spark plugs but not the right but i was running radiator cleaner through the system today when the car stalled out and i started it back up and ran for 1 min and then stalled out again and i noticed the cast tank was empty so i got gas and tried to start it again and nothing well i noticed water under the car and found that water is coming from the backside of the engine by the timing cover could this cause the car not to start from coolant being on the timing belt?
Old 10-15-2010, 08:42 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: Help!!!!! civic wont start help asap plz!!!
Dude you seriously just named several reasons why it won't start: oil in the water, oil in the cylinders, running radiator cleaner, water leaking from the block.
Sounds like the engine is toast man. #1 don't always believe what people tell you that they done to the car, sounds like a cracked head gasket caused the oil in the water and probably oil in the cylinders. #2 Radiator clean or stop leak is terrible for engines, if you have to use it, plan on replacing the engine soon. #3 if water is coming out from the timing cover, the water pump is going out or has been going out, which could have caused the previously mentioned problems in the first place and was never fixed.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 10-15-2010, 08:55 PM
danielsatur danielsatur is offline
When you took the plugs out, did you find one that was very clean and smell like coolant.
1) Fix the water leaks 1st.
2) check engine oil, radiator, and coolant reservoir for contamination.
Old 10-15-2010, 09:19 PM
well it ran fine today when i was running the radiator cleaner through their is no water in the oil just oil in the water mainly in the resivior but i talked to my dads friend who specializes in hondas after i made the post and he told me to start with the distributor to check for spark and everything cause fuel pump kicks in and the car ran good b4 it stalled and wouldnt start engine had power wasnt hotrodding was just surprised how touchy the peddle was so i will keep yall informed on what progress i make tomorrow
Old 10-15-2010, 09:40 PM
Tony's Avatar
TLD Member #1
Well I had a nice explanation typed out, but my browser decided to update without asking.
Anyway to sum up what I tried to say: Water leaking from timing cover means water pump bearings are going out, water is leaking from the weep holes like its supposed to to warn you, water pump going out could cause it to overheat at some point and crack the head gasket, allowing water and oil to mix(doesn't matter where, it mixed, which is bad), and allow oil in the cylinder, oil in the cylinder could keep the engine from starting by saturating the plugs enough to keep them from firing, or just keep the engine from turning over entirely because you can't compress a liquid.
I have had my fair share of experience with these cars as well. My engine ran fine before the piston decided to start slapping the head. So the fact that you think it ran fine before this happened, doesn't mean nothing was wrong. Mine also drove from Little Rock, AR to Dallas, TX atleast with the water pump going out.
Your engine has issues man, you can keep slapping band aids on it or check it out right. up to you. I have offered my advise and maybe the second time it will be used.
Tony
98 Grand Prix Wont Start, need help ASAP! atdudonis Grand Prix 3 06-17-2010 09:57 AM
Help Major Electrical Issues Wont Start I Need Help Asap! Ahhh crmodels Problem Diagnosis 3 08-21-2008 09:13 AM
car wont start help asap! bigciccone Celebrity 7 04-06-2007 02:41 PM
87 tbird tc my engine wont start help?plz eckounltd7285 Thunderbird 5 11-19-2005 10:48 PM
car wont start, help asap blackwidow6p '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 09-13-2004 08:42 AM
